Wheel bearing installation question
    I have one of my new wheel bearings pressed into its carrier but have hit a question. My notes are these hubs did not have circlips fitted (which are a useful stop for the bearing) on the inboard side, but I don't have any decent photos of the original installation position... well none I can find so far.
    I know from old notes that I am looking for about 1-2mm clearance from the back of the hub to the carrier when it is pressed into the bearing, but I don't want to press the new bearing too far into the carrier. Does anybody any good pics of original bearing installation positions ?
  • John.
    • 2615
    If it's the same as on a 20vCQ ??......I pressed the bearing in until it stopped......and had no problems on reassembling.
    • simon20vq
      • Dec 2010
      • 1379
      Hi Paul, I did the same as John on my old rs2 and s2 no issues.
        Hi Paul,
        Good to see you have more time and are able to post on here more often and that your Coupe is getting some tlc.
        Best wishes.
        • mcandmar
          • Apr 2004
          • 5118
          Press the bearing into the carrier until it bottoms out. Use an outer race from an old bearing to press against, if you try to press it in with the inner race you will damage the new bearing.
          Then press the hub into the bearing until it bottoms out. Support the back side of the bearing by the inner race or you will split the bearing in two.
          91CQ20v - Gone to a new home
          93UR-S4 - The Magic Carpet
          94S2Bus - The Emerald Express
            Cheers all - just did some measurements and the only way to get all 37mm depth of coverage on the outer bearing surface is to bottom it out as all suggested here. Done one and looking good. I used a 74mm drift on the rear bearing so I think thats close enough - good tip on reusing the old bearing shell as a drift though. I tell you they are a lot easier to press in than they are out - all went with a helluva crack.
            • mcandmar
              • Apr 2004
              • 5118
              If they are factory original they can be stuck real tight, but will come out like butter if you need to do them again.
                All done - the fronts took a few attempts to get centred properly - no drama. Thanks for the confidence check ! Now just the boring job of finishing to paint them, slide in the refurbed hubs and tick one more box of tasks done - thats one more than all of last year !
                  One of mine wasnt 100% home and it wouldn't bolt up so i had to go back to the shop and get them to finish the job.
                  I've got your strut tool here btw, if you'dlike it back? I dropped you a PM ages ago
                  • Davi123
                    • Feb 2016
                    • 98
                    Any one know if there is a wrong orientation for installing these bearings. I’m doing all four, none are magnetic it seems but the two front ones have an off centre marking in inner race so just got me thinking??
                    This gallery has 1 photos.
                      • Dec 2017
                      • 5984
                      Yes! One side is chamfered on aby bearings.
                      • Davi123
                        • Feb 2016
                        • 98
                        Thanks Dave.
                        • Davi123
                          • Feb 2016
                          • 98
                          I can see the chamfer in the hub, strange the bearings that came out weren’t chamfered. They just had been pushed up to the chamfer that has a lip.
