RARB options over and above the normal path of the Whiteline option.
After speaking with Doug some time ago at MRC, I was aware that he had put a Coupe Quattro FARB on the rear of what has now become the MRC600.
I've also found that TOm was running an S2 FARB on the rear.
I've just priced up Doug's setup and it works out a bit cheaper than the Whiteline option. However, the RS2 FARB that I was thinking about getting has rocketed in price. I will try a few more sources and see if I can get it cheaper but first quote is £200+
I have 2 questions for Doug:
I also read that Tom fitted the original S2 FARB to the rear and that this required the rear struts to be swapped to sort the drop link positioning. This is a stiffer setup again and Doug was of the opinion that, whilst it was fun, it was a bit too much.
Questions for Tom:
Cheers in advance for any answers
I'm looking at running this with standard springs and the Koni shocks to maintain some ride comfort and a standard ride height to reduce damage on the ever increasing number of speed bumps that seem to be around. The dampers are stiff enough to keep body wobble in check and I'm hoping that the ARBs will reduce the body roll that I get in long corners (e.g. motorway roundabouts).
- Did you keep the same drop links on the car (the rose jointed / Saxo hybrids) and if so, how did they take the punishment.
- What was the final length of the drop links from bolt to end of the threaded bar protruding from the ARB.
Questions for Tom:
- Is there a write-up of fitting an S2 FARB to the rear? (I had a quick look but without success).
- Did you run an RS2 FARB?
- What drop links did you use? Standard rear, standard front?
- Were the bushes and retaining cups the same as you originally had on the front?
- Did you keep this setup or was it just too much?!
). Amazing what you look at to take your mind off the iron block I5 that's 1" from your nose...
. RS2 ARB has shot up in price recently. These things happen I suppose
