Coupe Rear ARB options aka FARB on the rear of a coupe
This is a sticky topic.
Another way of mounting the old style short droplink front arb to the rear, but mounting it to the struts. I had not seen this before.
Cut off the BJ from a droplink, thread and put it through the bush
http://forums.audiworld.com/showthread.php?p=18308889
What is the effect of mounting the same arb, but linked to the struts, or the wishbone?Current-2004 Impreza PPP wagon
Sold ABY-stockComment
Not much difference in it, the arb mounts to the wishbone and exerts more force because of the shorter lever but has less travel, whereas the strut has more travel but is further from the pivot so exerts less force. I think AndyC worked it out to be about equal in the scheme of things
Imola B6 S4 AvantComment
That's how Doug did it, I'm sure there's a link right at the start. The issue is that the strut mounts are not that strong, so putting this setup on ripped one of Doug's off. Best to mount to the wishbones IMO.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
Bumping this back up because it's a great resource and I have some questions
So I'm currently fitting a setup I pieced together some years ago for a sedan onto my lastest coupe. It is an RS2 front bar and a 25mm arm mounted FARB from a late /89 built 90 which still retained the 2 bolt arms and arm mounted bar.
I had this on my 90 years ago, but never had a chance to drive the car much with it before the 7A died.
If I'm looking at it right this bar is what some 20x the stock bar?
TIASean
91 CQ Elanor 1.9L compound Turbo build. Fully built internals, full race oval port head, custom race cam. GT2256v and hy35 in compounds.Comment
This thread is GOLD and I can't thank you guys enough
I have an aby coupe with kwv1 suspension
I followed this thread and got myself a front anti roll bar of an audi 80 cabriolet with bushes and clamps (rusty helped me find the right one where the ends look hooked)
Took aby rear anti roll bar off swapped struts over left to right right to left
The cabriolet roll bar bolted straight up with standard aby drop links no mods needed at all as mentioned above
Just thought I'd post up letting you know this works with kwv1 aswell as the other suspension variants mentioned
Ps don't comment on the appearance of the underside being a bit on the rough side haha ... not had chance to have it in the body shop or rear 4 pots on yet!
Sent from my SM-G950F using Tapatalk
Nice work, what is the clearance like on the wishbone ? I had seen references to it being quite tight at full suspension travel.This thread is GOLD and I can't thank you guys enough
Clearance looked very good nothing touches at all HOWEVER Iv been for a drive and have noticed a very minor knock while going over speed bumps... now I'm going to check it over in a couple weeks time as I'm going away now and car is being picked up for all exhaust redoing (previous owner very bad job) and I'll recheck clearances while on the floor and double check everything's tight
should be a minor thing hopefully
Highly recommend doing this with 25mm bar like I have and stock s2 front handles an absolute dream !
Yh I know mate but was trying the standard drop links with my kwv1 suspension as no one has yetOriginally posted by Bowie69If it's the drive shaft or the wishbone, a cut, sleeved and welded up drop link will do you fine!
I'll move onto shorter links once Iv tried all options so if someone else uses v1 suspension the info will also be here with the rest of it
In the mean time does anyone fancy making me up a set just incase haha
