Coupe Rear ARB options aka FARB on the rear of a coupe
This is a sticky topic.
  • Rusty
    • 18953
    I'm just trying to look into the effects of the levers moving different amounts. I'm concentrating on the fact that the angle of twist is less and also that the relevant component of the force exerted also changes...
      Right. Painted up my rear subframe, wishbones and ARB, and also got the droplinks and bushes etc sorted. Reached the first stumbling block
      Something's missing from the equation:
      Heres one wishbone and the lower droplink bush and sleeve:
      You can see the hole the bush is supposed to mount in, here with the bush in
      The trouble is there is some king of sleeve missing off the wishbone to fit the bush into:
      The pressed wishbone is only approx 4mm thick with an oval hole:
      Mr Casey kindly took some pics of his Febi rear wishbones that came with the bushes already installed. You can see the bush mounts into a sleeve that looks to be pressed into the wishbone:
      I also noticed that one of the rear wishbones that I stripped and painted is bent
      Don't know how I didn't notice it before - i'll be needing one new wishbone anyway
      Weird thing is Andy said the bushes are pressed into the holes on the front facing side of his wishbones, and AFAIK the arms are also sided.
      Since 20v.org reconed that the US coupe quattros shared their rear wishbones with the front of the 4000Q, i wonder if our wishbones are different.
      If i'm right in thinking, what was called a 4000Q in the US was an 80 quattro over here? So therefore the 80Q front wishbones should match our rears
      I might see if i can find one and compare to my CQ rear one here.
      The other option that involves some work is that I strip the wishbones back, enlargen the hole slightly, weld in a sleeve and some spacers either side and then may as well seam weld the wishbones too.. I'd rather a plug and play solution TBH.
        Havong been inspecting my good wishbone and doing some (rough) measurements I'm wondering if the wishbones aren't symetrical, and can tehrefore be swapped to the other side :mischeif:
        I'll give Pete at QC a call and see if i can go and have a look at some on Saturday
        • stiglet
          • Aug 2007
          • 1264
          ....... or i could dig out my old wishbones (if i still have them) that have the bushes in and are probably not bent?
            If they are indeed symetrical that would be ace mate!
            hopefully I won't bend them getting the bloody bushes out
            • stiglet
              • Aug 2007
              • 1264
              They should still be in the mess of parts somewhere. They will need lots of TLC though.
              I'll have a gander tomorrow.
                Cool - hope so mate
                • Rusty
                  • 18953
                  Al, there's a possibility of swapping if you really want to go this route, let me know.
                  • stiglet
                    • Aug 2007
                    • 1264
                    Dug out the old wishbones today, and they are completely different Presumably because they are meant for the front and not the back. They are not even close to being symetrical and have the bush for the ARB in the middle instead of at either side.
                    I definately have seen a wishbone like yours though on the front of one of my cars somewhere, and I reckon it's on a series 2 coupe. That might be your best bet?
                    Sorry dude!
                      I've got a feeling the ur FARB droplink just has a threaded end and bolts through the hole in the wishbone with 2 washers and 2 rubbers. I'll have a look under the car tomorrow.
                        No worries Al, thanks for having a look
                        I had a look at the front of a UR round at Sal's earlier, and the wishbones definately won't work, they are offset not symettrical like the CQ rear ones...whether the sleeve on the wishbone can be swapped i don't know
                        i'm going to pop down the GSF tomorrow and have a look at all the wishbones they've got and see if i can find a match.
                        • Rusty
                          • 18953
                          Of course you could just go down the tried and tested route and file this under interesting exercise? I understand if you have to follow it through though, it's exactly what I'd do and why this thread exists in teh first place
                            exactly mate
                            I've started now, I need to finish
                            Although had one of my wishbones not been bent I might have called it quits. I am sure this will be a nicely balanced match for the 26mm bar upfront, and a great mod. Even if i have to but new rear wishbnones with the bushes in them its still cheaper than a Whiteline rear bar
                            • Rusty
                              • 18953
                              I got mine from Pete @ QC.
                                How much roughly?
