So I have the old style four spoke airbag steering wheel on my Coupe. I picked up a lovely early S8 three spoke airbag wheel from Bertman (thanks). I thought it might be a straight swap but unfortunately the spline shaft diameter is different and the horn ring is also different
I've done a bit of reading here and haven't found any clear guidance about swapping. I do have a 95 80 cabriolet here I'm breaking and it has the same spline as the S8 steering wheel. However, it appears to be a dash out job to swap the steering column and ignition switch. Anyone done this before?
