Old style airbag swap
    In fact I’ve never heard of anyone changing the spline either ..
      • Dec 2017
      • 5983
      The shaft is the wrong diameter for the new wheel so that had to be changed. If I use the old switches, the lower cowl doesn't work with the new steering wheel. You can't swap the cowls over either as the design is different. The old wheel has a copper ring for the horn.
      • mdz
        • Jun 2012
        • 775
        • Country: Latvia
        You need to swap connector housings and everything except (IIRC) low beam is p&p by wire colors. Pin on low beam ir different diameter, solder or crimp it from donor. I've done this few times.
        • struikie
          • May 2019
          • 314
          Is't in German though... sorry
          There is a spline adapter.... partnumber = 191419514A
          https://www.ebay.co.uk/sch/i.html?_f...9514A&_sacat=0
          JW
          | project | 1993 Audi 80 VR6 turbo quattro |
          | daily | 2018 BMW G31 530d | 345bhp 770Nm |
            • Dec 2017
            • 5983
            Originally posted by struikie
            https://www.audifieber.de/faqdaten/U...ag_Lenkrad.pdf
            JW
            Excellent. German classes start today
            • K Simmonds
              • Dec 2007
              • 7627
              Glad you've found an answer to your problem Dave, it looks like one of those jobs one kind of wishes they hadn't started, still I'm sure you'll be able to complete it now you have that info.
              1990 B3 2.0 80 quattro.
              1992 C4 2.8 Avant quattro
              1994 MTM RS2.
              1998 B5 TDI quattro Sport.
              2000 B5 TQS.
                • Dec 2017
                • 5983
                It's not gone to plan
                I have a thick white wire not mentioned in the guide and my thick yellow wire won't fit where they suggest. This is a can of worms
                • K Simmonds
                  • Dec 2007
                  • 7627
                  Oh dear, that's not good, there'd be some airborne tools if I was trying to do that job! I'm sure there's probably a fairly straight forward solution, however as you well know electrical modifications are best not conducted by trial and error. Maybe Alex (Error404) can help, he's pretty hot on this side of things if I recall.
                  1994 MTM RS2.
                  2000 B5 TQS.
                    You have to change the crimp on the yellow wire apparently
                    • struikie
                      • May 2019
                      • 314
                      I have that wire here. The replacement wire comes with both ends crimped, but I only used one end.
                      PM me your address and I'll send it to you.
                      JW
                        • Dec 2017
                        • 5983
                        A friend translated the document for me and I've changed the pin as mentioned
                          • Dec 2017
                          • 5983
                          JW
                          Thanks very much for the offer but I had a donor car here with the right pin. This is strange as the donor car, 1995 80 cabbie had this very steering wheel but the pin outs were slightly different to the guide. I have tried the guide arrangement and the cabbie but neither works properly. Headlamps don't come on. I will get my multi meter out tomorrow and test what goes where. It's only a bloody switch for God's sake!
                          • struikie
                            • May 2019
                            • 314
                            I can't remember that I had much difficulties during my swap
                            Just followed the table per connector old pin to new pin...
                            JW
                              • Dec 2017
                              • 5983
                              JW
                              what age is your car? This seems the critical factor.
                                • Dec 2017
                                • 5983
                                And have you got a pic of the wiper connection?
                                Looking at your pic you have the red wires different to the guide. I will try that tomorrow.
