Powersteering spraying out of crosshead bolt
  • nribs
    • Aug 2015
    • 91
    https://www.ebay.com/itm/293907385319
    These are the actual replacement specs.
    Be very careful removing the X-plug screw. They can actually be very difficult to remove.
    • Rikki Kitto
      • Feb 2010
      • 6276
      Remember having to buy the special socket for it when I found out it was £25 I used the end of my crowbar
      • Chris5044
        • Feb 2005
        • 1663
        The sollution to this issue, was replacing the 'o' ring. Which I did. Havent had an issue since. Also fixed the overheating issue, with swapping the radiator cooling fan connections, as recently found out that the fan was pushing air in the wrong direction, thus making the engine hotter.. which could have added to the o ring perishing also.
        So all good here and no leaks.
