Hydraulic Pump Knocking
  • willg54
    • Jun 2009
    • 2055
    Car is back, confirmed I was an idiot putting copper washers on the banjo. I'll whip them off, hopefully that's it sorted!
    1996 Audi S2 - 295bhp and 326lb/ft - Complete Rebuild Project
    1994 Audi 80 - 2.0 8v (slow but reliable!)
    • willg54
      • Jun 2009
      • 2055
      Confused... Etka calls them orings. Search the number, they're washers...
      • K Simmonds
        • Dec 2007
        • 7627
        I'm pretty sure they're supposed to be alloy crush washers either side of the banjo bolt.... Etka is translated from German so is riddled with errors when it comes to the correct English terms for items, though I'm surprised it doesn't simply call them 'washers'.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • nribs
          • Aug 2015
          • 91
          For some hidraulic lines with banjo end fittings, there is I think some version that actually used o-rings. There is a groove for the ring in the fitting. I don't actually know which cars had this but if you search those p/n a rubber o ring does show.
          ​​​​​I did the same thing last year,..
          ​followed Etka to my detriment.
          • willg54
            • Jun 2009
            • 2055
            I think I have it fixed... Took me all of 9 minutes.
            The pulley bolts had wound off every so slightly. Doh!
            Loctite and retorque. Job done.
            • psiconauta911
              • Oct 2007
              • 613
              • Country: Portugal
              #21
              Nice you solved it in the end some times is just dificult to find the soure of the fault, usually not that expensive just a pain!
                I once convinced myself I had a really bad CV joint… even got my mate to ride in the back of the car to check which side… turned out the wheel bolts were loose, nice quick roadside fix though
                • K Simmonds
                  • Dec 2007
                  • 7627
                  Yes, your quite right there version that use's a distinctive red rubber O-Ring.
                  Glad you go it sorted Will and hope you've found the cause, nice when things are quick fix even is partially down to your error.
                  1994 MTM RS2.
                  2000 B5 TQS.
