Stabilizer, ARB (anti-roll / sway bar(s)) 893411309B vs 895411309
I had the same concerns about drilling out the hubs, but I compared them to a set of 14mm stock ones and as far as I can see they're the same casting just with smaller holes, it is only 1mm off each side so not a huge diference.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
The part number for the 8L ball joint nuts is... N01222307. They cost me 67P each plus VAT in 2015. So less than £5 to do the six required, I don't understand why people don't change them as they should come up as being single use on the garages computer.
Trust me you do not want to experiance the result of those nut's working loose. It very nearly killed me, I was lucky and going 50 MPH but if it happed at high speed I'd probably have been dead.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
Glad You're still alive and kickin' !!!The part number for the 8L ball joint nuts is... N01222307. They cost me 67P each plus VAT in 2015. So less than £5 to do the six required, I don't understand why people don't change them as they should come up as being single use on the garages computer.
but can't find N01222307 (in ETKA)
Is it this one You think of ?
Img is from ETKA : A3 1998 (407-010)
Part # : N 90808801
dimension : M12 x 1.5
Measured outer dia to be 19mm at the thinnest part on a spare set with 12 mm bolts, bolt hole is ~12.5mm.
(19 - 12.5) / 2 = 3.25
(19 - 14.5) / 2 = 2.25
2.25 isn't much but guess it's ok with std bolts as it's not most "stress" at the middle part
but,
wtb if using camber bolts ?
The "stress" would be in the middle, at the weakest point :0
p22140.jpgComment
