WHAT type of rear bushes should i go for?
  • Flat on my back
    • Jan 2007
    • 2449
    My Bentley says '40nm then a further 1/4 turn with the vehicle on the ground'.
    Carlos.
    • s2driveruk
      • 12696
      Noticing that there is movement between the bolt shank and the sleeve in the bush, enough for there to be some movement which is odd, it was enough to fail the front driverside bush nearest the footwell.
      could it just be a slightly inferior size shank on the bolt for the size it should be or something else??????
      David
      1992 3b S2 Coupe
      • Welleh
        • Aug 2005
        • 106
        anyone noticed that with the powerflex wishbone bushes its impossible to get the nylon washers that they supply in both sides? i could ony manage to get one on the inside of each one, not on the outside! they seemed fine although i fear they may squeak! i did mine to 40 + 1/4 turn aswell! - what a **** it is to get under and get a spanner inside the frame with the car on the ground tho, had to do it whilst car was on a high kerb, no chance of doing it on flat ground!
        • Mikes2
          • 1704
          The Bentley manual doesn't cover the S2 and this figure is incorrect.
          Correct value is 70 Nm + 90 degrees.
          Mike
          http://www.s2-audi.co.uk
          • Welleh
            • Aug 2005
            • 106
            i read this off of http://www.s2-audi.co.uk/tech_articl...sh_replace.htm
            theres a table at bottom of the page!
            you sure your not thinking of subframes?
            • Flat on my back
              • Jan 2007
              • 2449
              need to replace rear wishbone bushes on my 90 quattro sport(B3), for MOT
              Covers this one though.
              Carlos.
              • Mikes2
                • 1704
                It was me who wrote that page and that is for the front bushes. If you check the table carefully you'll see it states 40 Nm + 180 degrees.
                The rears are 70 Nm + 90 degrees which is linked here
                Mike
                • Welleh
                  • Aug 2005
                  • 106
                  diddnt realise that! awesome site tho, really resourcefull! sorry for quoting you off of your own website..!! lol
                  i assumed it was the same for the rear as the front, thats what ive done it too anyways, looks like i'm running a bit slack then!
