H&R Coupe Springs pics (fitted)
    I'm looking at some uprated springs for the CQ (running stock S2 suspension ATM)
    Looks like S2 Avant front springs al round are the best option in terms of cost and availability - i'm just a bit concerned about ride height being a bit odd looking as the coupe rear spring platform is higher and the weight at the rear lower too - sounds a recipe for a low front and a high rear.
    Has anyone got an pictures of their car with H&Rs fitted - ideally i'd like to be able to compare both the specific coupe fitment H&R do and the Avant F&R setup.
    Can anyone help point me in the right direction?
    cheers
    Alex
  • andyg plym
    • Nov 2006
    • 4646
    cheers
    Alex
    Alex,
    low front + high rear = DRAGSTER.....i'd do it mate,better still il get the local chavs to rob you some 13" fiesta pepperpots for the front and some 19" Scabalier rims fresh from s***** for the rear..............hardcore baby
    • dest
      • 4287
      Hope this helps, before and after fitting H&R's, no other mods atall inbetween pics suspension wise
      BEFORE
      AFTER
      Ive also got this close up of a before shot, I can take a similar angle after one in the morning to match it if you wish
      • andyg plym
        • Nov 2006
        • 4646
        BEFORE
        AFTER
        Dest,perfect mate end of. im defo sold now on re-lowering,is yours -40mm?
        • s2driveruk
          • 12696
          Hi Alex,
          Mine on proper coupe setup H&R's and Bilsteins:
          hope that helps
          David
          1992 3b S2 Coupe
          • ciaranthemurph
            • 696
            Originally posted by s2driveruk
            Hi Alex,
            hope that helps
            David
            Where did you get your H&R's and Bilsteins from? Are the billies adjustable?
            • andyg plym
              • Nov 2006
              • 4646
              david, i got one word mate..........SUBTLE.
              looks lush,i wonder how the nouvalari rims would look on yours?
              • s2driveruk
                • 12696
                no the bilsteins are fixed rate (B6 model) I got the springs from AMD years ago and the billies from ebay.de for silly money
                1992 3b S2 Coupe
                • ciaranthemurph
                  • 696
                  Thanks, I'm off on the hunt now.
                  • stiglet
                    • Aug 2007
                    • 1264
                    If you use much stiffer springs on the rear compared to the front (compared to ideal rates) then it won't just sit higher it will oversteer more too
                    • dest
                      • 4287
                      No idea TBH!
                      Just dug out the original receipt, and it is just listed as S2 Avant B4
                        Thanks guys,
                        David - yours looks perfect
                        No sign of the reaqr being too low as has been suggested in some threads i've seen
                        Keen to see how the avant fronts look all round on the coupe - from what i've read the avant fronts all round will induce more understeer but I'm going to be running a very stiff rear ARB so not sure it will make a massive difference.
                        Trouble is until i do my 20vt swap next year i'll not have as much weight preloading the front, so i might have to live with it looking a bit odd until then
                        • s2driveruk
                          • 12696
                          yeah never understood that either
                          1992 3b S2 Coupe
                          • Lloyd
                            • Apr 2006
                            • 1559
                            You can run a less stiff RARB to help balance this out. I think Mance in the US was an advocate of running stiffer springs and less roll bar for optimum handling.
                            RS2+ (now sold...)
                            • DJ-ROY
                              • Dec 2004
                              • 710
                              What a beautifull pics and cars in this Topic .
                              The height looks perfect with H&R .
                              RS for ‘Rennsport’ - ‘Motorsport’ in German
