S to the afe
Top mounts... AGAIN!!!
@Jamo - How can a void exist ?
Basically the Mount savers are inserts that clear the bushing and sit inside the upper bearing cup on the oem Boge strut mounts to increase the contact area. The 034 mounts are manufactured with the increased contact area from the beginning, essentially a "cast in" mount saver...
Mance did alot of bench failure testing on the stock style mounts as part of developing the mount savers - settled on the dealer Boges as being the longest lasting and designed the mount savers to fit within the profile of the Boges...
As far as I know know one has failure tested the 034s side by side with the Boges.Peter S
1990 ErsatzS2 - track toy
1991 Coupe Quattro
1991 Coupe Quattro
1995 S6 Sedan
1995 S6 WagonComment
Got my 034 ones through from Joe @ Axis motorsport. They look beefier which is good, looking forward to fitting them and the freshly powdercoated H&Rs. Looking at about ÂŁ20-ÂŁ25 each for them delivered as I got stung for charges and VAT.
1994 ABY Coupe - Projekt AlpinweissComment
Be interesting to hear how they compare to stock mounts Andy - i've just had new subframe and wishbone polybushes up front, resulting in massively improved feel, stability and compusure - will be going with Track density mounts in the near future, hoping for better turn-in and steering response coupled with new track rod ends
Imola B6 S4 AvantComment
Sounds cool andy, so do these work in conjunction with normal blue/green topmounts or something seperate.
Gotta get around to fitting all this soon, a rs2 farb turned up in my boot earlier brand new so I think I should get that fitted especially considering how much it weighs.
Still on the back of mine and I've not noticed any issues there. S2driverUK had them on the front of his S2 and I don't think they lasted any better than stock. quattro corner sell the same sort of thing (Meyle HD). They're not harsh as they're still rubber. HTHCheers'en, AndyC
Paul
