Top mounts... AGAIN!!!
    S to the afe
      @Jamo - How can a void exist ?
        Haha ah we could be here all week
          Paul
          • PeterS
            • 423
            Basically the Mount savers are inserts that clear the bushing and sit inside the upper bearing cup on the oem Boge strut mounts to increase the contact area. The 034 mounts are manufactured with the increased contact area from the beginning, essentially a "cast in" mount saver...
            Mance did alot of bench failure testing on the stock style mounts as part of developing the mount savers - settled on the dealer Boges as being the longest lasting and designed the mount savers to fit within the profile of the Boges...
            As far as I know know one has failure tested the 034s side by side with the Boges.
            Peter S
            1990 ErsatzS2 - track toy
            1991 Coupe Quattro
            1991 Coupe Quattro
            1995 S6 Sedan
            1995 S6 Wagon
              Got my 034 ones through from Joe @ Axis motorsport. They look beefier which is good, looking forward to fitting them and the freshly powdercoated H&Rs. Looking at about ÂŁ20-ÂŁ25 each for them delivered as I got stung for charges and VAT. .
                Be interesting to hear how they compare to stock mounts Andy - i've just had new subframe and wishbone polybushes up front, resulting in massively improved feel, stability and compusure - will be going with Track density mounts in the near future, hoping for better turn-in and steering response coupled with new track rod ends
                • Acidburn
                  • 13459
                  Sounds cool andy, so do these work in conjunction with normal blue/green topmounts or something seperate.
                  Gotta get around to fitting all this soon, a rs2 farb turned up in my boot earlier brand new so I think I should get that fitted especially considering how much it weighs.
                    They're sort of the same as the stock mounts but with more rubber to make them better. Price delivered from the USA was not much more than some blues.
                      I've got the track mounted ones to cope with the extra weight up front
                      • Acidburn
                        • 13459
                        Ok i'll keep an eye on this thread as currently I have front/rear brand new blue top mounts so i'll see how long they last
                        • powercar
                          • May 2008
                          • 93
                          • Country: Norway
                          #27
                          so, did anybody here got some feedback on these 034 top mounts? good or bad? harsch to drive with?
                          IG: Alb garage
                            Still on the back of mine and I've not noticed any issues there. S2driverUK had them on the front of his S2 and I don't think they lasted any better than stock. quattro corner sell the same sort of thing (Meyle HD). They're not harsh as they're still rubber. HTH
                            • Al Wyn
                              • Nov 2006
                              • 3746
                              Got a pair of new greens on the for sale board if anyone needs them pm me
                              S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
                                The Meyle HD ones are holding up pretty well on my coupe, at least taking a lot of kerb at Oulton hasn't immediately f**ked them like OEMs
