Extended ball joints for lowered suspension?
  • stiglet
    • Aug 2007
    • 1264
    Originally posted by magarv
    Have you calculated the new roll center and get them to machine a custom length extender or are you going for the "stock" 1,5" length?
    Keep us posted on delivery time, price etc
    I am planing to do rebuild my suspension geometry this winter myself. Tubular wishbones, extenders etc.
    I know my roll centre is very close to, but still above, ground level. I haven't worked it out exactly because it's quite tricky getting exact measurements when all the drivetrain is in place
    To be honest, i'm more interested in the potential for better camber change in corners but less roll will help with that anyway.
    • magarv
      • Jul 2004
      • 323
      • Home: Norway
      #32
      Originally posted by stiglet
      Finally got hold of the guy. He is making a batch now but it will take 3 weeks. They have to be heat treated, which I'm happy about to be honest!
      I'm in a state of denial about the clearence issue. I'm hoping it's just a 1-peice strut thing....
      Any news? Received the extenders yet?
      "Ring addicted"
      8,43 BTG with trafic and roadworks:http://www.youtube.com/watch?v=pYg50Bg2lVQ
      • stiglet
        • Aug 2007
        • 1264
        Nope. Not heard anything, I'll contact him in the New Year. He should be finished by now!
        • redz
          • 222
          Very interested in this Stiglet.. As i said before they worked a treat on the MK1..
          Andy
          s2 new project
          On going !!!
          • stiglet
            • Aug 2007
            • 1264
            Andy
            Good good, I'll keep this updated.
            • stiglet
              • Aug 2007
              • 1264
              Have got in touch with Dave at PMW and he has some in stock. Just waiting to hear back on a couple of other bits and they'll be on the way
              He is now making a bump steer kit which goes with the extenders. He's going to check to see if they will fit the Audi (they are designed for the Golf, mk 1, 2 and 3). If so then I'm getting a set of those too.
                #37
                Any links
                to the Golf bump steer kit?
                Thanks.
                • stiglet
                  • Aug 2007
                  • 1264
                  Here is the homepage
                  There is a pic of both the extenders and bump steer kit on that page, then details in the catalogue section.
                  • redz
                    • 222
                    Thanks.
                    Yeah my mate had a kit on this mk2 its a spacer that lets the track rod arm sit level
                    from what i can remember anyway
                    .. Nice work stiglet..
                    s2 new project
                    On going !!!
                    • magarv
                      • Jul 2004
                      • 323
                      • Home: Norway
                      #40
                      Good news!! Anyone know if balljoints "pin" dimensions and the tierod end (for bumpsteer kit) for S2 are the same as for the Coupe?? (Stiglet: You have a Coupe right?)
                      I dont have my car in my workshop at the moment so I am not able to take any measures
                      "Ring addicted"
                      • Rusty
                        • 18953
                        I'd be a little dubious fitting Golf bits to an S2 based on the fact that the front axle of an ABY takes the same weight as a Golf. Worth doing some sums IMO just to be happy. Are the BJ extendeds treated in any way? I hope they're machined in such a way to minimise step changes and thus stresses?
                        • magarv
                          • Jul 2004
                          • 323
                          • Home: Norway
                          #42
                          I agree on the Golf vs S2 thoughts and you can do some sums on this with measuring the lateral G-forces with ie an Performance box or G-tech, then calculate the torque arms and forces. Maybe run some simple fatigue analysis in Ansys or similar...
                          But I still think it would be difficult to get any accurate numbers without spending "months" with work.. The extenders still have to fit the original ball joint "pin". And if the S2 has 19mm it is obvious that the extenders also have to be same dimension regardless of what the Golf has.
                          There will be more moment/tourqe and higher forces in the extender, but if you keep to the "stock" 1,5" length as PMW deliver I dont think it will be any problem since the extenders are made in high strength 4140/4142 steel and heat treated to a tensile strength of 150,000 PSI. And as I can see of the pictures on their website the design has a nice large radius to minimise the step change.
                          The same is the matter for the tierodend for bump steer. The extender have to be big enough to fit the hole in the "steering arm" on the mac pearson leg. (upright?) And I guess this also is in high strength steel and have a robust design.
                          "Ring addicted"
                          • stiglet
                            • Aug 2007
                            • 1264
                            I can confirm they are heat treated and have been used on the Audis before. A few people on Motorgeeks are using them. Also, the ball joint pin is 19mm so should fit snug
                            I reckon in terms of strength both kits will be fine. If I get this fitted problem free in time for Feb I can test this at Snett so I'll let you know how it goes.
                            I'm a little Dubious about the bumpsteer kit as to whether it will fit and work, and if the geometry is even remotely close to that of the Golf. The kit might even make things worse! If it doesn't fit it's not the end of the world.
                            Will update as and when anyway...
                              #44
                              Thanks Stiglet,
                              Can't quite appreciate the bump steer kit, but that just me.
                              Adopting a wait and see stance, and following your updates. Like the look of his castor "plates" for the top of the strut, pity his photos can't be blown up to "inspect" same in greater detail.
                              Thanks again and kind regards.
                              • stiglet
                                • Aug 2007
                                • 1264
                                Received these today, but I won't be fitting them until after my trackday on the 8th Feb as I have JUST had my alignment done. I know fitting these is gonna mess up everything and it will all need adjusting again.
                                In the mean time, I beleive I have found a solution to the brake disc fouling problem, so will give it a go and update.
                                Also, I undertsand how the bumpsteer kit works now and I'm sure It won't work for the Audi. Cost peanuts compared to the extenders though so not too bothered.
