Rear tie rod bush
  • stiglet
    • Aug 2007
    • 1264
    Forgot to mention if you want to compare the front and rear bushes that would be great also, thanks for your help
    • goodall
      • Jul 2008
      • 810
      #32
      well found the bush and compared it to the steering arm bush's, its bigger, so a second use at the front isnt possible
      its same bush used in audi 100 front steering arms from the late 70's to the late 90's and on typ 85Q typ89Q rear tie rod aswell, so it is quite common...
      if theres a group buy there maybe people on the quattroforum intrested
      • stiglet
        • Aug 2007
        • 1264
        Thats fairly common. Have you got the bush at hand? If i gave you an address could you forward it to Powerflex? I'll Paypal over the cost of postage for you.
        • hibby
          • Apr 2007
          • 215
          Ooooh, I am interested mate.
          1990 Cq20v GTi Engineering RE2400
          1992 16v 80 quattro
          2004 A3
          • stiglet
            • Aug 2007
            • 1264
            Good to know it really depends on Powerflex though wether this happens.
            If/when we get the go ahead, i'll start a group buy thread.
            • goodall
              • Jul 2008
              • 810
              #36
              ah sure wont cost much to post
              the bush is on the desk here, can send it tomorrow so they would have monday
              so yep forward me the address and what to write as a letter ill send it
                #37
                I'd be interested
                in a gb for a powerflex style inner bush on the owner's standard arm that an owner could fit themselves, if a gb goes ahead. ( Two grades - track or street - too complicated? )
                Would be helpful if someone could post up a "photo" of an S2 rear one - if applicable, to help myself and others appreciate what the rear one looks like?
                Thanks.
                • stiglet
                  • Aug 2007
                  • 1264
                  This may seem like a really dumb question, but i notice people aren't mentioning Coupe or Avant, is there a difference on the rear tie rods??
                  • goodall
                    • Jul 2008
                    • 810
                    #39
                    This rear tie rod system on a advant, part 1 is tie rod
                    this is the tie rod in a coupe, its this part and the bush in it i started this thread about and i am assuming its still about this part...
                    for the home mechanic poly bush is handy as you burn the old bush out and then clean the hole abit and new buh just slides in place by hand
                    • stiglet
                      • Aug 2007
                      • 1264
                      Yep that part is the bit i'm thinking of
                      Poly bush would be fantastic as they are so easy to install. Not to mention the potential for improving the handling.
                      • stiglet
                        • Aug 2007
                        • 1264
                        Got this reply from Powerflex today.
                        Hi Alex,
                        I’ve had a look and we have nothing that is similar and would therefore suit this application
                        Because of the location and size of the bush, using 2 top hat type bushes will not be appropriate as the bush would try and pull out with any sideways forces applied
                        I will send the part back to your friend
                        Thank you for efforts in supplying the original part
                        Oh well, nevermind...
                        Anyone else got any ideas?
                        • mcandmar
                          • Apr 2004
                          • 5118
                          I missed the first part, which bush is this?
                          91CQ20v - Gone to a new home
                          93UR-S4 - The Magic Carpet
                          94S2Bus - The Emerald Express
                          • stiglet
                            • Aug 2007
                            • 1264
                            Rear tie rod, probably the more neglectd of bushes unless you've ever taken off the rear subframe or something.
                            • mcandmar
                              • Apr 2004
                              • 5118
                              Sorry just noticed this was a "Rear tie rod bush" thread
                              I remember the bush your talking about, the inner subframe mount. Are you sure hes right about it being an open ended mount, i'm almost sure it was enclosed each side. I.e. two top hat mounts should do the job?
                              • lind4hl
                                • Jul 2008
                                • 2465
                                i am going to build my rear tie rod for my rs2 in stainless steel with a uniball in each end. and instead of the crappy originla adjustment i will have it udjustable almost like this:
                                i get hold of uniballs in stainless high quality pretty cheap, i can make maybe make some more sets of these when i start making them. i will make a new thread about this though.
