You thinking of Superflex? I thought they made their own stuff?
Rear tie rod bush
Nope. AFAIK Superflex and Superpro are the same products. Originally made by Graham Scudamore Smith in Australia.
I haven't seen any evidence of bush manufacturing at Wookey anyway, only storage.SSComment
I could pop round to see Chris Witor to ask him what he thinks, he's usually quite helpful. I could take one of my tie rods over, although I don't fancy removing the bush in case a solution can't be found.SSComment
Just to bring me up to speed, this is the bush we're talking about?
That'll be typical, as the rear tie rods are amongst the few parts that are currently fitted to my car.
I'll get under the car tomorrow and take one back off.SSComment
TBH I think my tie rod bushes are ok. But obviously polyurethane will be an improvement.
Have you changed the rubber joint in the steering column?
I'll be interested in a polyurethane version of that.
SSComment
Yes, the column is in 2 parts. They are attached by 2 pins which are through 2 rubber bushes, although quite little amount of rubber there. The idea is that if you crash, the pins will slide off the bushes, so the steering wheel does not penetrate your chest. It may require the removal of the dashboard to properly access that joint.Comment
