Rear tie rod bush
  • stiglet
    • Aug 2007
    • 1264
    Yep, i looked into that but it's so expensive for 4 heim joints (decent ones anyway)
    Looks like i have no choice though
    • stiglet
      • Aug 2007
      • 1264
      Originally posted by Error404
      good news. I'll be interested to hear if/how they improve the steering feel
      Just thought i'd update this. I recieved the 034 front tie rods a while back, but there was a small problem with the thread on one of the rods so had to send it back to 034. They've sorted this now so should have these back/installed soon.
      The heim joints are quite sexual, so small threading issue aside i'm quite impressed and looking forward to fitting them
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        #48
        You have problems with clearance to the down pipe?
        I whant to buy same thing and i am curious iff will fit there with an 3" pipe.
        Thanks!
        Eugen
        • stiglet
          • Aug 2007
          • 1264
          Haven't fit them yet but will update. I believe the rods are custom made so they could put a bigger kink in there for you if you wish. Mine are completely straight, no turbo.
          • stiglet
            • Aug 2007
            • 1264
            Have finally fitted these today. First impressions are steering is more responsive. Though there doesn't seem to be any more feel, haven't driven very hard though.
            I think the trackday in Feb will reveal more.
            • goodall
              • Jul 2008
              • 810
              #51
              did you get the tracking set? if tracking is sitting with toe out the sterring will be dull, i think
              • stiglet
                • Aug 2007
                • 1264
                Yep got the tracking sorted straight afterwards.
                It's difficult to tell because i'm on my spongy everyday 15" wheels and tyres, but i'm sure there is a much quicker response to steering input. Usually there is a small "lag" in the steering. Now it's lightning quick. However the steering "feels" the same, given that i just went for a little blast on the local roads. I'm sure that when I start pushing harder I'll notice a difference then.
                Definately an improvement though
                Really want to do the same on the rear!
                • Pirvu Eugen
                  • Apr 2007
                  • 1978
                  • Country: Romania
                  #53
                  Thank You! I will order 1 set for me!
                  The only down side off these i can see is that all the vibrations will be transfered directly to the steering gear.
                  Dont know how much this will affect.... but....better then 100 euro for 1 at Audi.
                  All the best!
                  Eugen
                    Good to hear they have made an improvement Al, i know exactly what you mean about the "lag" in the steering - feels nasty.
                    • 90quattrocoupe
                      • Nov 2003
                      • 771
                      These people list the bushing 431-419-809 as a replacement part. You may want to give them a ring.
                      Greg W.
                      • stiglet
                        • Aug 2007
                        • 1264
                        Found a polyurethane bush company at the Autosport show who might help with this. They said that at the very least they could give me a bush that was close, and show me how to machine it down to the correct size.
                        They gave me a sheet to fill in dimensions and send off to them, so will get that sorted then update.
                        • goodall
                          • Jul 2008
                          • 810
                          #57
                          Originally posted by 90quattrocoupe
                          iv seen the autosuppliers one before and was put of by all being bout supply for industry and not private consumers ete
                          woho result then maybe
                          whats the name the company?
                          • Mr.Crossfire
                            • 145
                            Interested in some poly bushes if you have those made.
                            Polyurethane can be machined, I've done some myself. You just need an extremely sharp tool to cut the poly, as it flexes and bends away when applied force. I guess that harder the material, the easier it would be to machine. Freezing it can also help, but I guess it doesn't stay frozen for long because of the heat generated in the machining process.
                            • stiglet
                              • Aug 2007
                              • 1264
                              This company specialises in providing materials that are easy to machine yourself. I don't know exactly what this will mean, but it's definately progress.
                              The company is called Super Pro. website is here.
                              • 4WheelDrifter
                                • Oct 2004
                                • 5773
                                • Country: Devon
                                #60
                                That's interesting. 2 companies in Somerset 12 miles apart both being European distributors for Fulcrum Suspensions's polyurethane products.
                                SS
