bilstein and h&r´s where to buy?
  • lind4hl
    • Jul 2008
    • 2465
    hi, i have been looking around for coilovers but i must strip my old and send them to germany and wait a looong time.
    so ive read that bilstein shocks with h&r springs would be the best? (after coilovers?)
    where do i buy this?
    the rs2 springs are diffrent(harder) than s2 or?
    cheers!
    the 2 bennet coilovers, how are them? must i send in the cores?
  • Jonas_R
    • 3781
    • Country: Denmark
    I would go for the H&R CUp Kit and has the bilstein dampers and H&R 50/50 lowering springs.
    I bought mine from www.reinekeshop.de I paid 720 euro inlcuding tax and shipping to Denmark.
    Then dont list the kit on their site but send them and email and you should be good to go.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
    • lind4hl
      • Jul 2008
      • 2465
      mailed
      • Jonas_R
        • 3781
        • Country: Denmark
        Just noticed that you have an RS2, I'm not sure if the cup kit actually fits the Avant.
          Jonas R
          Is the H & R Cup kit harder or softer than any other H & R kit?
          Do H & R, ( or anyone else ), do a spring kit that has the ride comfort of the standard springs, but is say 30/40 or even 50mm lower?
          I'm looking for standard spring comfort but with lower ride height springs for aesthetic reasons.
          Is there such a kit with coilovers?
          My car is an ABY Avant btw.
          Thanks.
          • lind4hl
            • Jul 2008
            • 2465
            h&r does coilovers, but you must send in your cores to them ant it will take long time. thats why im not doing it.
            jonas_r : okey, i will ask them
            • goodall
              • Jul 2008
              • 810
              Coil Springs Direct the only supplier of Original Entex Stock Springs. For all your spring enquiries & to take full advantage of our expertise, contact us now.
              they can make you custom springs, ie 30mm drop but stock rate or no drop but 30% stiffer ete
              there was agroup buy on the quattroforum, i got some for my 90 and they seem good, but there was a issue with spring length, so might be recommendable to specify to coil spring what you need free length to be, ie about 2" min the distance from the top and bottom seat of your suspension . to maintain preload sudden be a problem if your using up-rated shocks i think was decided i think as they tend to be shorter
              • giorgioS2
                • Oct 2006
                • 102
                • Country: Chile
                Hi, where you succesful mailing www.reinekeshop.de ? I sent an email, but no answer still (about a week ago)
                Cheers, giorgio.
                  Goodall,
                  Originally posted by goodall
                  http://www.coilsprings.co.uk/
                  Thanks for the info.
                  Kind regards.
                  • A80Avant
                    • 10873
                    • Country: Greece
                    can you explain a bit more the part about the preload?I have an S2 avant suspension and im thinking of sending them the whole thing so they can use to make either some lower springs or some modified coilovers on that suspension.Will they need any other info except the amount of drop i would like the car to have?For example if i ask for a 15mm drop with OEM spring rate,can that be done and still the car have the proper bump stops,and no other problems?Should the springs be progressive?
                    • lind4hl
                      • Jul 2008
                      • 2465
                      i has not got any mail from them yet, any other shop where i can buy the h&r cup kit for b4 avant?
                      • karlblues2
                        • Jul 2004
                        • 402
                        • Home: England Current: Australia
                        Hi I had H&R's fitted on ABY Coupe 3 years ago. I paid AUD $800 deposit. They used some that they had and I sent off my OEM shocks once I'd fitted the H&R's. Have you asked if they still offer that service?
                        Karl
                        Oz
                        Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
                        Audi 90 Quattro 20V 1989 7A
                        Audi TTRS 2010 APR stage 2 +
                        Triumph 675 Street Triple R
                        • Skull
                          • 3506
                          • Country: Slovenia
                          in the bilstein katalog there are front strut inserts of 50mm and 55mm, how to know what i have on my car?
                          Audi Quattro WR
