Death of a steering damper?
  • stiglet
    • Aug 2007
    • 1264
    No more than usual, though it's hard to say with big boots on my wheels. They tend to grab at things anyway. When I change back to the Speedlines and get my tracking sorted I'll update.
      cool
      • lind4hl
        • Jul 2008
        • 2465
        thatgreat stiglet! becuase i working on my rs2 to be a track weapon so all bushing in delrin and alu and so on, so i will remove this damper me to!
        • stiglet
          • Aug 2007
          • 1264
          If it's for track use then I reckon you should remove the damper, I really can't see what use it could possibly be on track. I'm sure it's there just to stop the steering wheel from snatching at your hands if you hit something.
          • lind4hl
            • Jul 2008
            • 2465
            yeah,that what i also think, you cant get enough feeling, will remove it during the weekend
            • s2driveruk
              • 12696
              i have mine installed and can't see any downside to it after being round the ring and castle combe a few times.
              1992 3b S2 Coupe
              • lind4hl
                • Jul 2008
                • 2465
                i think the steering will be more quicker and light steered (?) without the damper?
                  I want heavier steering!!!
                  • stiglet
                    • Aug 2007
                    • 1264
                    Yeah, but heavier through feel, not artificial damping
                    • s2driveruk
                      • 12696
                      disconnect the power steering pump lol
                      1992 3b S2 Coupe
                        I wonder if you could put some kind of restrictor in the fluid line to the rack to reduce its assistance
                        • s2driveruk
                          • 12696
                          i think you can but i think you need to do the opposite and increase the diameter. Someone like pirtek could easily make one up.....
                          1992 3b S2 Coupe
                            Hmmmm...... might be worth investigating :mischeif:
                              Well, it was far too cold to be crawling around under the car removed the steering damper today, but about 3/4 of a turn more pre-load on the rack, and it now feels like the steering wheel is actually connected to the wheels
                              I did it in little bits, maybe a 16th of turn at a time, and kept dialing in more until the wheel didn't want to self centre, then backed it off a bit.
                              Steering is heavier, loads more "feel" and the car darts about the road like a kart compared to how it did before. Definatley worth a fiddle
                              • stiglet
                                • Aug 2007
                                • 1264
                                Brilliant maybe I should give this a try on mine.
