Death of a steering damper?
  • LHD_Kid
    • May 2006
    • 3695
    #76
    Originally posted by panzerwagen
    Error404 bet you would not be saying that if you owned a LHD car. There is so much junk and obstructions that it is nearly IMPOSSIBLE to remove the part! Audi says you have to remove the following on a LHD car just to replace it...
    1/ Master brake cylinder
    2/ ABS components
    3/ Coolant bottle
    4/ Assorted Vacuum lines and assorted hoses.
    Well, mine is LHD, and I reckon I could change that from above in around 30-40 minutes.....
    • panzerwagen
      • 900
      LHD_Kid..you can do it in 30-40 minutes?!
      Do tell. I would like to hear this.
        don't forget Chris you have no battery tray in the way on a LHD S2
        TBH it would be impossible from above in a RHD coupe too, it has to be accessed from below - therefore can't see what good removing the ABS / master cylinder would be anyway on a LHD car
        • LHD_Kid
          • May 2006
          • 3695
          #79
          Very true..... I keep forgetting this... with the battery tray there it would be pretty difficult....
          Panzerwagon, if you have no battery in the way, there are no tricks, small ratchet handle, 10 minutes undoes the bolts on the rack end, fiddly for the other, but not difficult... its the access to the brake servo end which is fiddly...
          • Mcstiff
            • Oct 2004
            • 504
            The battery tray does have an access port in the bottom of it.
            1995 1PissedOff90sigpic1991 USDM CQ 7aT
              Fitted new Boge steering damper today. I must say the Boge item is loads lighter than the Stabilus OEM damper, but equally stiff - its harder to compress than an ABY Boge turno gas insert i've got knocking about theb garage
              I cut a big hole in the battery tray to fit the ******, made life loads easier
              Comments following fitment: the car feels more solid and stable, more "audi-like". The steering doesn't get upset by uneven road surfaces and bumps as it did without the damper. IME theres no noticeable decrease in steering feel or feedback.
              After running without one for a couple of years and about 3k miles overall feedback is I much prefer the car with the steering damper.
              • panzerwagen
                • 900
                LHD_kid wrote >its the access to the brake servo end which is fiddly...<
                Yup that is what sums it up in a nut shell. It is near impossible on a LHD car with the servo and the other PS components plus the ABS componentry also in the way.
                To even see the end of it under all that stuff would take the X-ray vision of Superman!!!
                  Can't you access it from below?
                  • veneto rs2
                    • Jun 2006
                    • 1022
                    • Country: Veneto
                    #84
                    Glad you agree with me.... and that you sorted out eventually.
                    Funny how it improves the allover feeling on the steering department isn't?
                    Stefano
                    http://www.audisportclub.com/
                    http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
                    • Rusty
                      • 18953
                      Thread exhumation...
                      Just wanted to confirm that the Boge item is part no 22-747-1. Has anyone tried the Febi item 27613 on a RHD? It states the LHD number as the OE equivalent... Any other part numbers?
                      • Rusty
                        • 18953
                        Just ordered a Boge one for £46 delivered
                        • Rusty
                          • 18953
                          So, got the part fitted today (what a faff the wing side bolt is ).
                          The one I received was a Stabilus 6784HX and it was identical to the one I removed (8A0425021) from my 94 ABY coupe.
                          • GazzaG60
                            • 4133
                            my 16v doesn't have one. is it worth fitting one. never an issue with steering before
                            • Tom_
                              • Oct 2007
                              • 1301
                              • Country: Czech Republic
                              #89
                              Does anyone have an experience with febi damper or swag one? Looking for a new one as the engine is removed.
                              Odesláno z mého ASUS_X00QD pomocí Tapatalk
                              Audi Coupe Quattro 2.3 20V
                              • nribs
                                • Aug 2015
                                • 91
                                I bought a Sach one recently on Ebay.
                                Seller no longer has any, but this is what I pulled from my purchase history...
                                Steering Damper Sachs SG401027 fits 94-96 Audi Cabriolet
