Not that simple i'm afraid, assuming same material is normally okay i think but often different heat treatments are used so cant assume the materials side, also you need to know the angle of the coils, also if your springs are anything like the springs on the cq then the angle changes as does the diameter
from a basic test i think the cq springs are softer on the rear simply as i can compress the rears a small amount but not the fronts, however manufacturers can also vary the heat treatment throughout the spring essentially making it progressive, would surprise me if audi did this as the rear weight will constantly be changing.....
why do they have to make it so complicated!!!!
lol
Ant
from a basic test i think the cq springs are softer on the rear simply as i can compress the rears a small amount but not the fronts, however manufacturers can also vary the heat treatment throughout the spring essentially making it progressive, would surprise me if audi did this as the rear weight will constantly be changing.....why do they have to make it so complicated!!!!
lolAnt
Thanks!
