(and it was the offset I was referring to - greater distance between those two points will increase the self-aligning torque)
Steering weight and feel
So wider track with wider contact patch should be a good thing then ?
Only downside being maybe some increase in bump sensitivity thru the steering ?Paul Nugent
I'm as confused as ever then... well almost...
I am definitely running with wheel centres 2x4mm further outboard than factory... Due to offset change.
I am definitely running 20mm wider contact patch on the tyres.
My track is definitely wider as a result.Paul Nugent
Originally posted by S2central.net View PostI'm as confused as ever then... well almost...
My track is definitely wider as a result.sigpic
1992 3b S2 Coupe
Your wheel centres are 14mm further apart, but your track is even wider if you have fatter rubber. 225 rubber is nominally 20mm wider than stock, so add 10mm track each side for half the wheel width... Thats a track width of 14+20mm bigger than stock - you are 6mm wider than me by nature of your smaller +ve offset.Paul Nugent
Depends on what you think of as "track" ...the original definition is largely based on the centreline of the wheel, not the outside width ...but there is contention as to where even that centreline is to be measured, whether it is at the hub centre or the contact point (I prefer contact point).
Regardless of all that, the increased overall width brought about by wider rubber, combined with more offset, does increase the outer extremity of the tyre contact width - which in itself is bound to be of benefit to the lateral acceleration the car can achieve, with all other factors being equal.
The whole issue of what is in contact with the ground is a moving feast anyway, as the tyre pushes into the road on the loaded outer wheel in cornering, and the geometry inevitably moves as well as the tyre compressing ....things change!Martin Cutting
With lots of camber, remember, that the tyre lifts at the outer edge - so that effectively makes the width between the outer extremes of the contact patches smaller than if the same tyres at the same pressure were used with less camber. In harder cornering the contact patch will surely start to move outwards as more of the rubber meets the road.
In motorsport applications, it would be fair to say that maximum use of the tyre would be the most beneficial way - equal temperature across the width of the tyre. BUT that is only true if the tyre is able to come up to operating temperature. If it cannot achieve that, it is better to use less of the rubber (eg more camber) and get a smaller portion of the tyre working at the correct temperature.Martin Cutting
Originally posted by Keeper of The Kitten View PostWith lots of camber, remember, that the tyre lifts at the outer edge - so that effectively makes the width between the outer extremes of the contact patches smaller than if the same tyres at the same pressure were used with less camber. In harder cornering the contact patch will surely start to move outwards as more of the rubber meets the road.
The coupe has next to no camber compensation Keeper, so I think you can safely assume the camber is always positive on hard cornering
