Promounts and Konis issues / pro mounts
  • Flat on my back
    • Jan 2007
    • 2449
    Originally posted by Rusty
    I'll try and remember, might be able to do a pic.
    Think I've identified what I need to do to resolve the issue.
    Less wine me thinks...like to know the answer too.
    Carlos.
      No David, you've got 034 street density voidless ones...
      Will solve the issue another day...
        Reading up whatever I can find on a search, it looks like Promounts should come with specifically machined lock nuts to suit, I got mine secondhand so on such nuts. Will have to dig further tomorrow (well this morning actually )
        • s2driveruk
          • 12696
          ahhh ok
          1992 3b S2 Coupe
          • mcandmar
            • Apr 2004
            • 5118
            I got two thin lock nuts with mine, as above you have no castle nut as the space is needed for the spherical joint. ....and yes it makes fitting them a PITA.
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • mouse
              • Apr 2008
              • 374
              • Country: Australia
              #21
              Thats correct, also the machined nuts are described as 'uni-torque' nuts which are a type of lock-nut.
              Although I'd recommend using some thread locking compound too - I had promounts put in when changing front shocks about a year a go and the nuts started to work thenselves loose in a couple of weeks.
              If you want to see if you can get the nuts from Mance who makes the promounts, you might be able to contact him on Salinas212@aol.com
                Right, that's what I think most of the issue is. I'll have to get on the lookout for some thin nuts.
                Fitting is quite simple actually, What we did was assemble teh strut off the car and put the top nut on so that it help it all together, then when you put the weight of the car on the strut you can take the top nut off, fit the top cup and re-fit and torque the top nut. Nice and simple really
                  Which way round did you fit the 'top hat' sleecve? Rim uppermost or lowermost?
                  My only remaining concern is whether the rim is to be used as a spacer (lowermost) or a retainer (uppermost).
                  This picture shows the parts of the mount:-
                  • mouse
                    • Apr 2008
                    • 374
                    #24
                    The Link doesn't work for me, [EDIT: works now] but I'm pretty sure the 'top-hat' sleeve is on top of the mount.
                    I queried the assembly order after mine started coming loose as I thought maybe the nyloc nut was meant to be on there too. I found the email where Mance replied:
                    Pro-Mounts are correctly assembled in this fashion:
                    1. Center bushing is inserted from top.
                    2. Pro-Mount w/bushing installed is assembled on strut.
                    3. Machined lock-nut (and no other) is tightened to threaded strut shaft.
                    That's it!
                      Cheers for the Email, I've chucked a couple of questions to Mance and have included this lovely diagram to clarify the sitation.
                        Originally posted by mouse
                        The Link doesn't work for me, but I'm pretty sure the 'top-hat' sleeve is on top of the mount.
                        That's it!
                        I'd have thought I'll receive the same info then! I'd better get looking for a thin section locknut.
                        • GazzaG60
                          • 4133
                          cant remember with mine but i do remember the dont wind down as far.
                          no probles after 2 years though
                            Very fast reply from Mance and very helpful too, not a one liner but a description of what he needed from me and what I should look for as a work-around etc. I've supplied the required dimensions and he's working through the iussue with me to ensure that I'm supplied the correct lock nuts (that are ordinarily sent out with the PMs from the factory). He was keen to make sure that the second hand parts that I was fitting were in good fettle (they were unused so no worries there) and TBH I was very impressed
                            To clear up any confusion, the centre bush sits with the shoulder uppermost (see diagram above), as I've fitted them and then the reduced height nut sits on top.
                              Mance is a top bloke spoken to him a few times
                                #30
                                maybe you just need a slimline locknut then Rusty ?
