rs2 rear hub conversion on 80quattro
  • Skull
    • 3506
    • Country: Slovenia
    sorry, we have to start from the beginning. this is a mess.
    tell me what geatbox and what rear diff are you going to use.
    then tell me which axles (the engine) do you have at home.
    Audi Quattro WR
    • saltinot
      • May 2004
      • 1946
      I have everything RS2 now so everything is good. My experiment was from some time before now. I wanted to find a solution for US people who want RS2 hubs using US available parts. I have a front outer CV from a 80 v6 quattro that I will try on my rear axles from the 80 v6 quattro. We will see.
      But for Sam we need to find a solution. If what you say is true then he should be able to use 80 v6 quattro rear axles with the outer CV from the front.
      • Skull
        • 3506
        • Country: Slovenia
        if we are talking about the B4 cars, i belive only the V6 engines were available, so they should already have the larger cv joints, therefore the rs2 hubs should be bolt on.
        the other B series cars need the CV joints mentioned - V6 engined B4 quattros CV joints (30 38).
        Audi Quattro WR
        • saltinot
          • May 2004
          • 1946
          The B4 80 V6 quattro limo rear axles will not work with the rear RS2 hubs. The CV is too small. This I do know 100% because I have tried it. The only way for these to work is to use a larger outer CV.
          • sam80quattro
            • Oct 2006
            • 1496
            oh lol mine is/was a b4 16v quattro.......
            • sam80quattro
              • Oct 2006
              • 1496
              thread resurection... has anyone got any pics of rs2 hubs with the cv in and fastened too the car but without the bolt going into it? ive got a cv joint to fit both the shaft and the hub but the splines only come halfway through the hub, is this right? thanks
              • Skull
                • 3506
                • Country: Slovenia
                #22
                hmm, sounds about right...
                Audi Quattro WR
