Lowered Nightmare
  • Rikki Kitto
    • Feb 2010
    • 6276
    Lowered Nightmare
    Just lowered my 1994 S2 with Jamex springs, mmmm looks nice handles much better. Unfortunately this may have shown up a problem, the left frront is approx 5mm inside the arch the right front is approx 3mm outside, strange. Tyre now hits the arch on compression of spring over bumps.. I have had someone suggest changing the wishbones etc not sure this will sort it, any ideas.
  • tyler
    • Jun 2010
    • 38
    sounds like a knackered shock bud
      The bottom ball joint slides in and out of the end of the wishbone and is locked in place by the bolts, have a look to see if one is adjusted out and the other in.
      Jack it up and see if there's any play anywhere.
      • Rikki Kitto
        • Feb 2010
        • 6276
        Many thanks for your suggestions guys, am going to replace front shocks and wishbones. Anyone know if Monroe shocks any good can source them at nice price?
        • Acidburn
          • 13459
          don't think its shock, think as newsh mentioned its the ball joint thats moved/come loose. I've had this before and really easy to check. Also worth checking that everything is tight and done up properly.
          • Rikki Kitto
            • Feb 2010
            • 6276
            Thanks, will ave a look tomo fingers crossed. Was havin' nightmares about twisted chassis and the like. Any views on powerflex bushes anyone?
