Power Flex rear diff mount install
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    #31
    Hold the joint to the diff and try rotate the prop to see if there is any play.
    1996 S2 ABY Silver
    • montyrs2
      • May 2008
      • 522
      Is this the right way for the rear diff bush to go in?
      • Bowie69
        • Nov 2013
        • 2675
        Yes.
        • montyrs2
          • May 2008
          • 522
          Conflicting opinions?
          Top picture the larger shoulder is up, mine is rearward. Been told both are correct?
          • sjw185
            • 1175
            I put mine in with the wider part facing upwards as that seems to be where the diff is trying to go under heavy foot drivin
            • montyrs2
              • May 2008
              • 522
              Just spoke to Powerlfex. Shoulder is there to stop bush moving sideways rather than for any other reason so doesn't matter where the shoulder is.
              Guess i'll leave it where it is then.
              • Bowie69
                • Nov 2013
                • 2675
                Sorry, yes I missed the difference, but I was told elsewhere it was supposed to be at the rear, but if Powerflex say what you say then it makes no odds
