Right the time has come that my S2 really needs a full suspension overhaul.
As far as I know at the moment it has a set of koni inserts and H&R springs and tbh there crap there abit soft and bouncy. Whether this is down to other worn components im not sure as I know the front arm bushes aren't the best.
All I really want to know are peoples opinions and past experiences with different bushes and suspension set ups.
Ideally I do want a GOOD handling car as most of my previous cars have had polybush suspension of some sort and coilovers.
1st: What is the best suspension strut assembly to use i.e shocks/springs + makes or coilovers. Im not to fussed about price but i do think that new KW v3 are too pricey. Also I am willing to loose ride comfort, Id rather a hard ride than one that feels loose like it does now. Also if you could add good spring weights then that would be helpful.
2nd: What bushes should I replace the suspension arm front and rear bushes with, standard, poly or other?
3rd: What bushes are best to replace the subframe bushes with, standard, some sort of poly (if available) or ally bushes? I have looked at 034 ally bushes and also VRS bushes and the grading is alot softer grade of ally than the 034 bushes, has anyone used these with good results?
4th: What top mounts are the best to use with either suspension set up, I understand that these to go with a regular occurrence.
5th: What anti roll bar upgrades are worth doing, front or rear? I understand that the whiteline rear can take awhile to arrive but is it worth the wait?
6th: Engine and gearbox mounts... I already have the rear diff side bushes and a poly rear diff mount ready to go. Is going standard eng/trans mounts still a good option?
and what front snub mounts are available on the market either standard or other.
Any help would be more than welcome!
Tim.
Tim.
