Pas x-head leaking
  • s2driveruk
    • 12696
    Pas x-head leaking
    Hi,
    Changed the screw cap and new washer last night after soaking the seal in fluid for about 9hrs. installed them and fired it up, bled the system doing the lock to lock process and it would appear that the tell-tale sign of bubbles from the x-head screw is back again
    Any ideas why, the screw is well seated and I carefully cleaned the mating faces for a sound seal but somewhat p**sed off that straight away i have a weep again.
    Any ideas other than pulling the pump off and hurling a decent distance
    David
    1992 3b S2 Coupe
  • A80Avant
    • 10873
    • Country: Greece
    may be a long shot, but...
    since its leaking again, im wondering if there is too much pressure building up on the brake side of the system. There are 2 screws that the hose which is on the top side, that goes to the bomb has, and they have a little mesh in them to make sure that no dirt particles go to the bomb/brake system. Maybe they are too dirty and if the seal of that hose is good, they are pressurising the pump and its leaking from there.
    just a thought...
    those bolts can be easily reached and cleaned with some spray cleaner of some sort.
    • Jas11n
      • 5067
      Originally posted by s2driveruk
      Hi,
      David
      What did you tighten it up with Dave?
      Seem to remember a figure of 120nm or there abouts.
      I made a tool to get that after to first one I replaced leaked as I couldn't get it tight enough.
      I got lucky in finding the real deal tool on ebay, but have misplaced it at the minute.
      Welcome to lend the tool I made if you want?
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • A80Avant
        • 10873
        • Country: Greece
        by the way, i hate the hydraulic stuff...
        • s2driveruk
          • 12696
          Wow, if its 120nm then i might be a tad shy of that
          I'll take a nosey in the garage and see if i can wind it up, if not then will definately take you up on the offer Jas....
          and yes, i HATE the green stuff, i hate the smell, i hate the way it coats everything, i hate the fact it always comes back lol
          The filter on the top banjo had a bit of gunk caught which i cleaned but otherwise the fluid was clean and bright as about 3yrs old
          1992 3b S2 Coupe
          • A80Avant
            • 10873
            • Country: Greece
            Im looking through the internet about this tool as well. I will be needing it it seems as i need to remove those 2 caps and retighten them.
            My car goes into the garage next wednesday and hopefully coming out on saturday and im pretty sure they dont have this key!
            David, if you dont find it and you need it from Jase, how soon can you get it and send it back to Jase or me?
            • A80Avant
              • 10873
              • Country: Greece
              the only shop i found it in. and its damn expensive!!!!
              found on motorgeek that a large drag link socket can also do the job.
              • s2driveruk
                • 12696
                $79 - ouch, time to improvise
                1992 3b S2 Coupe
                • A80Avant
                  • 10873
                  • Country: Greece
                  on another thread on motorgeek, they used a drag link socket of 3/4s to do the job.
                  i already emailed the garage to see if they have something similar to do the job next week.
                  • Jas11n
                    • 5067
                    The Samstag sales tool is the one I got lucky with on ebay.
                    Don't you just hate when you can't find something
                    So, who wants my improvised tool first?
                    • A80Avant
                      • 10873
                      • Country: Greece
                      If David doesnt find something to do the job, ill take it. Otherwise he came in first and has a problem that needs immediate attention, so..
                      • Ian Simmonds
                        • Jun 2005
                        • 2858
                        Dave, we had some success using two washers with the RallyRep. But ultimately, with that we were (as 80Avant has suggested) running way too much pressure on our non-standard set-up.
                        93 MTMS2 Avant
                        • s2driveruk
                          • 12696
                          just tried nipping it up a bit more but still a little stream of bubbles...i hate the p/steering system on these cars
                          Also the alternator is sounding like a supercharger whine and i have a tappety sound from the back of the head. Will change the oil/filter and see if she quietens down or it has another issue to present to me
                          1992 3b S2 Coupe
                            TBH as it seals with an O-ring it shouldn't need to be that tight.
                            Did you clean the 2 banjo bolt gauzes?
                            You sometimes can get a crack in the housing where the X bolt goes, remove the bolt and check carefully.
                            There are 2 other smaller brass plugs which unscrew with small O rings on them, these can be perished (from acid wash at the reconditioners) This was what finally fixed mine.
                              Isn't that a new alternator? Maybe its just the brushes wearing in?
