Hi,
Changed the screw cap and new washer last night after soaking the seal in fluid for about 9hrs. installed them and fired it up, bled the system doing the lock to lock process and it would appear that the tell-tale sign of bubbles from the x-head screw is back again
Any ideas why, the screw is well seated and I carefully cleaned the mating faces for a sound seal but somewhat p**sed off that straight away i have a weep again.
Any ideas other than pulling the pump off and hurling a decent distance
David
David
