Camper, Toe, Caster etc. settings.
  • Jonas_R
    • 3781
    • Country: Denmark
    Can anybody tell me the factory camber, toe, caster and so on settings for the s2 (3b 1992)?
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • audiman
    • 4827
    have a look on S2central.net. Its on there IIRC.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • Martynf
      • 1885
      Jonas,
      does this help?
      Martyn
      www.vagparts.com
      • Jonas_R
        • 3781
        • Country: Denmark
        Well it does help, a car company had to adjust my suspension, but it seems that they have adjusted it for a 80,90 quattro 1987-1991 so that kinda sucks. Will call them on monday and talk to them.
        /Jonas R.
        • Martynf
          • 1885
          oh, not good!! I hope they will correct it for you! good luck.
          Martyn
          www.vagparts.com
            Jonas - please note the MASSIVE tolerance in the factory spec's...
            Ask your alignment place to get as close to your desired setting as possible, but most important get it even on both sides eg - if you want (say) -2degrees camber at the front and successfully get that on the left side - but can only get -1.8degrees on the right side then get the left side setup for -1.8degrees.
            Note also the car should be filled with normal driver & passenger weights whilst alignment is carried out.
            Paul
            • NoNonsense
              Forum Sponsor
              • Apr 2004
              • 673
              Paul
              True, although, if you want to be really picky (like I am when it comes to my car), especially if you autocross or do a lot of track time, these adjustments should be done with the driver in the driver seat, helmet (or equiv weight on lap), and the same amount of fuel you'd use in competition.
              I autocross my car all the time, and this is how I adjust the ARBs, and my front strut bar. Every little bit helps.
              Joe "NoNonsense"
              axis motorsport
              joe@axismotorsport.com
              • Jonas_R
                • 3781
                • Country: Denmark
                Well this is the repport that i got, sorry for the bad image quality
                venstre=left , højre=right
                foran=front
                bag=rear
                Aktuel= the difference between the camper, toe etc.
                Looks bad does right?
                • RIX
                  • Jul 2004
                  • 229
                  • Country: Denmark
                  ja din camber er go fin i venstre side men højre side passer ikke med den venstre,der vil være nogle røde felter når du kommer med en bil der er opgraderet,jeg vil personligt have omkring 1 i negativ camber både for og bag,så kør den bedre i svingene,det går lidt ud over retnings stabiliteten men det er okey.så få dem til at lave den om.
                  RIX
                  • audiman
                    • 4827
                    Audi UR Quattro
                    • RIX
                      • Jul 2004
                      • 229
                      • Country: Denmark
                      having some problems with the danisch audiman
                      • audiman
                        • 4827
                        Yep, LOL
                        Audi UR Quattro
                        • Jonas_R
                          • 3781
                          • Country: Denmark
                          Originally posted by audiman
                          Yep, LOL
                          Hehe, yeah danish is hard to understand and speak.
                          Anyways Rix, I just emailed you with some question.
                          /Jonas R.
                          • audiman
                            • 4827
                            I was thinking the same thing. Just didnt want to show off with my expert Danish typing!!
                            Could you translate what RIX said for us english speaking ppl please? Would be nice to know what was said
                            Audi UR Quattro
                            • Stick Insect
                              • Dec 2003
                              • 2338
                              The frightening thing is that if you work through each word you can get the basic meaning of some words.
                              opgraderet = upgrade?
                              personligt = personally?
                              du = you?
                              side passer = passenger side?
                              negativ camber = shock absorber?
                              går lidt = Garlic
                              easy really
                              David
