the last three he he,the first ones spot on
Camper, Toe, Caster etc. settings.
Not that bad actually
opgraderet = upgrade? OK
personligt = personally? OK
du = you? OK
side passer = passenger side? Well "side" means ex. the right side of the door and "passer" means fits.
negativ camber = shock absorber? way off here "Negative camper"
går lidt = Garlic "går=walk, lidt=a bit" and not garlic, garlic is spelled hvidløg. Actually hvidløg means "white onion"
To Audiman, rix say:
Yes your camper is fine in the left side, but the right side does not fit with the left one. There will be some red marks when you come with a upgradet car. Personaly i would like 1 negativ in camper front and rear. Then it drives better in curves, it will make the stabiliti of driving straight a bit off, but that is oki. So get them to do it over.
That was very roughly translated.
/Jonas R.
Originally posted by Stick Insectgår lidt = Garlic
easy really
DavidJoe "NoNonsense"
axis motorsport
joe@axismotorsport.com
Hi
Here is print out from check I had done today. I am no expert in these matters. Could anyone provide an informed view of the readings? Are they OK? Car is '91, high mileage 3B Coupe.
Thanks
IanAttached Files'91 3B Coupe
Hi.
The left front caster measurement is highlighted in red and reads, 1°16'. The spec is +1°25 ±30' so it is in spec, however, the max permissible difference between side to side is 30'. You have a difference of 35`.
The LHS neads to be adjusted to correct this. HTH.
Nuvo
