Bushes - Opinions
  • DickyP
    • Mar 2008
    • 79
    Bushes - Opinions
    Gents, I have recently got a 1998 on 54k miles with full history, no issues etc but as it's 13years old which bushes would you recommend refreshing to tighten it up and improve the overall feel.
    Thanks, it's a V6 by the way but I'm sure it will apply.
    By the way excellent resource of info and it's my new fav forum.
  • MattyB1
    • Aug 2011
    • 15
    I was just searching for info on bushes Rich - well, 'trying', the spam-protection is doing my nut.
    Some helpful guides on the replacement here:
    Matt
    1994 RS2, RS Blue - Big Reds, Milltek, Bilsteins.
    • DickyP
      • Mar 2008
      • 79
      Pretty good how to's by the guys and good old fashioned access and nuts and bolts!!
      • Rikki Kitto
        • Feb 2010
        • 6276
        Powerflex poly bushes all the way Contact Pete at Quattro corner
        • Rusty
          • 18953
          A full set of quality Febi or OE rubber bushes will certainly make the car feel like new again - I did this and the car is much improved.
          If you're on the road, that should suffice but for track use, you'll want to tighten things up using poly / delrin / alloy - all depends how much NVH you can tolerate...
          • John B
            • Apr 2008
            • 926
            This link shows a definitive set of bushes / mounts. Paul includes an excellent table in post #27.
            Personally, i have Superflex wishbone and FARB bushes, new standard top mounts (some go with the blue urq ones though). About to go onto aluminium subframe mounts with 034 box, engine and diff mounts (street density). The RARB is Whiteline which comes with a set of bushes AFAIK. Rusty does an excellent snub mount.
            All that should really tighten things up!
            2001 996 C4 - Being renovated
            • DickyP
              • Mar 2008
              • 79
              When you say all the way which are you talking about, sub frame, wishbones, engine, topmounts, engine...
              It's a laid back cruiser so poly bushes won't suit it really, just want it tighter as per new. Also any links to part numbers with associated bushes?
              • MattyB1
                • Aug 2011
                • 15
                I think when he says "all the way" I think he's just voicing his approval
                Rich, I think OEM will be fine for what you want it for, Polybushes will be too harsh I think...
                Matt
                • johne
                  • Apr 2007
                  • 1405
                  First to get attention should be the wishbone bushes. Whilst it's true on many cars fitting poly bushes hardens things up on our cars I didn't notice any extra harshness going to poly and the car felt much better. OE rubber wishbone bushes don't last long on our cars and you can't fit new ones yourself unless you've got access to a press but you can get your old rubber ones out and fit poly bushes yourself.
                  Second to get attention should be the top mounts. Lots of contention on here as to which are the best. OE ones are cheap and good while they last but that won't be long.
                  Third might be the side diff mounts on a quatro as they take the reaction torque. OE ones are good and easy to fit.
                  That's where many of us would stop unless it's obvious you've got a sagging or banging engine/gearbox/diff/subframe mount.
                  John
                  • DickyP
                    • Mar 2008
                    • 79
                    Thanks all for your input, time to collect parts me thinks.
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      I don't find the powerflex bushes harsh at all, tighten things up nicely though
