Originally posted by martinws
View Post
how to mount chassis audi s2 on sedan type 85?
To sum up:
I have on my sedan all of the UR except the gearbox and rear I want to keep.
I have in stock of the S2:
- steering bars
- shafts
- struts (with hubs)
Can I fit all this of S2 but keep the subframe of my T85q?
Can i mount the S2 struts mount on the subframe of my T85q?
Thank you.
Originally posted by hajbed View PostCan I fit all this of S2 but keep the subframe of my T85q?.
Originally posted by hajbed View PostCan i mount the S2 struts mount on the subframe of my T85q?
Originally posted by caterpillar View Postthe s2 strut will fit.. the swaybar too... but the balljoint may be different...
The other solution is another model balljoint and keep my T85Q wishbones (19mm last B3 etc...)
You confirm?
Thanks.Last edited by hajbed; 12 April 2012, 17:06.
the s2 wishbone does not have the hole for the litle joint for the front arb; they does have a little ear/ bracket under the spring bottom; so you need all the front parts from a audi 20v or s2 verson... all parts will fit the subframe...
i have a vw 32b with the audi 20v( 170hp) front parts; everything; they did fit right in; exept i use the wishbone form audi 80 diesel( 91-93) they are asymetric and have 3(!!!) holes for the balljoint and 19mm tap...also the s2 farb, with the "rackelrods" under the spring bottom..
