loose top mount, does this seem normal?
Only gravity holds the top mount in place, so some movement when the wheel is in the air is to be expected. The movement should equal the gap between the body and strut top cap visible in the car
1994 ABY Coupe - Projekt AlpinweissComment
I dont agree Rusty, when I had OEM top mounts this never happened, I swapped to 034 track density top mounts I had this exact problem which I documented on the forum.
It sems the 034 top mounts are smaller in diameter
The 034 ones are being binned and I have Meyle HD onesComment
i had to bin my 034's too and likewise, went Meyle HD ones which look to be working pretty well so far
1992 3b S2 CoupeComment
yup, appear to be up to the task... my nearside one took a real thumper of a pothole and seems to be non the worse for it so farsigpic
I was trying to locate a clunk and although not caused by the mounts, when I removed them, the bearing has separated from the mount and so I got them replaced under warranty and rather than refit them, I decided to sell and look for another solution.Cheers'en, AndyC
The mount is smaller and moves around at the top with no load on the wheel
The OEM and Meyle fill the hole up top and dont move with no load.
It's not normal behaviour at all IMOComment
Where's the best place to get meyle hd top mounts in the uk?Comment
