All being well Kev, my car will be ready at the end of April or maybe earlier. I called in at the bodyshop this week and they are definitely on with it.
For those of you considering the top mounts, I have also gone for the same theme with the rear diff, gearbox and engine mounts.
Slightly off topic but I was wondering if Kev could make the sleeves of the cpilovers in stainless steel as they get surface rust fairly easily with the UK weather. Would be more robust.
Those engine mounts won't work Steve,as our mount that fasten to the gearbox and engine have slotted holes the engine will move under load as the poly is too soft to clamp them,if the mounts were not slotted they would be ok
Not having a go at kev just trying to be helpful
Sold over twenty pairs of these and no complaints yet
Stainless Steel threaded tubes would cost a fortune due to material costs and longer machining time
Reason: add info
