Top mounts! Whats the definitive answer?
  • bambridge
    • May 2009
    • 609
    Earlier in the post another set was going to start putting on miles from July, did that happen?[/QUOTE]
    The member has decided he wants to fit a coilover kit, and wants to do all the work in all one go, makes sence
    • DJones
      • Jun 2005
      • 2020
      The member has decided he wants to fit a coilover kit, and wants to do all the work in all one go, makes sence [/QUOTE]
      Was there ever a conclusive out come to this Kev ?
      Darren.
      • steverrquattro
        • Oct 2006
        • 788
        All being well Kev, my car will be ready at the end of April or maybe earlier. I called in at the bodyshop this week and they are definitely on with it.
        For those of you considering the top mounts, I have also gone for the same theme with the rear diff, gearbox and engine mounts.
        Kev also did me the coilovers as well.
        Steve
        1990 RR 20V
        1982 SWB UR - RS2 Engine
        • A80Avant
          • 10873
          • Country: Greece
          #79
          Slightly off topic but I was wondering if Kev could make the sleeves of the cpilovers in stainless steel as they get surface rust fairly easily with the UK weather. Would be more robust.
          • DJones
            • Jun 2005
            • 2020
            So does Kev now sell these top mounts?
            • cooperquattro
              • Jan 2011
              • 815
              Those engine mounts won't work Steve,as our mount that fasten to the gearbox and engine have slotted holes the engine will move under load as the poly is too soft to clamp them,if the mounts were not slotted they would be ok
              Not having a go at kev just trying to be helpful
              • cooperquattro
                • Jan 2011
                • 815
                I think he does and they look top quality
                • bambridge
                  • May 2009
                  • 609
                  Sold over twenty pairs of these and no complaints yet
                  Stainless Steel threaded tubes would cost a fortune due to material costs and longer machining time
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #84
                    i see.
                    thanks for that. i may be getting a spare set for the front tubes then at some point. will get in touch through Brian
                      see if you can find someone to cad plate them Vas
                      • A80Avant
                        • 10873
                        • Country: Greece
                        #86
                        Cad plate? What's that?
                        • steverrquattro
                          • Oct 2006
                          • 788
                          Ignore.......tried to delete.
                          Steve
                          1990 RR 20V
                          • mcandmar
                            • Apr 2004
                            • 5118
                            Any update on these top mounts Kev?
                            I'm getting desperate now for a decent solution, these "HD mounts" aren't worth a *****.
                            91CQ20v - Gone to a new home
                            93UR-S4 - The Magic Carpet
                            94S2Bus - The Emerald Express
                              Fingers crossed, Kev is currently making my prototypes
                              • Golfboy666GTI
                                • Sep 2008
                                • 571
                                • Country: New Zealand
                                #90
                                Has anyone tried either of these solid top mounts in there S2/RS2?
                                http://www.compbrake.com/cars/audi/q...ixed-each.html
                                Im thinking of putting some in my daily driven RS2, am I mad? Will they put to much stress on the chassis?
                                1980 VW Golf GTI Track Car
                                1995 Audi RS2
