Avant Front Shocks
  • Alistair E
    • 479
    Trying to make sure I get the correct shocks for the car now.
    I'm going for Bilstein B6's.
    What measurement do I need to quote? The od of the shock absorber is 49mm. The od of the strut is 50mm. Can someone please advise which I should quote when ordering.
    Alistair
    • Yaz
      • May 2007
      • 445
      You mean 55mm?
      Alistair
      1992 Audi 100 2.8 Quattro
      1993 Audi Cab 2.3
      1995 Audi URS6 Avant
      1999 Audi S8 D2 FL
      2005 Skoda Octavia Elegance Variant TDi
      2012 VW CC BlueMotion Tech DSG
      • Alistair E
        • 479
        Sorry, yes 55mm. Thanks for the correction Yaz.
        Originally posted by Yaz
        You mean 55mm?
        • tscheel
          • May 2009
          • 222
          • Country: Denmark
          I have this number for front : 34-030868 (please doublecheck)
          The insert don't fill the strut , but the aluminium top holding it in place is 55mm.
          Cheers, Torben
          '94 B4 Avant S2
          • Alistair E
            • 479
            #20
            What do you mean by the aluminium top? Is that part of the insert?
            • Alistair E
              • 479
              #21
              Well it looks like my supply of Bilsteins has unfortunately fallen through. Does anyone have any suggestions where to try for Bilstein B6's?
              As an alternative, are Konis suitable for running with stock springs? If so, which model of Koni and where's the best place to get them?
              Alistair
              • irishs2
                • Apr 2009
                • 2455
                Koni fronts are 86 2086SPD2 , not sure where you get them though.
                Eric
                95 S2 Avant under rebuild.
                • Yaz
                  • May 2007
                  • 445
                  1993 Audi Cab 2.3
                  1999 Audi S8 D2 FL
                  • tscheel
                    • May 2009
                    • 222
                    • Country: Denmark
                    #24
                    The threaded top cup holding the damper in the strut, it comes with the damper. Bilstein B6/B8's are "upside-down" dampers and therefore has a thicker rod than OEM, and the OEM top don't fit.
                    I guess the B6 damper for a 50mm strut is the same, but with different aluminium top.
                    Cheers, Torben
                    '94 B4 Avant S2
                    • tscheel
                      • May 2009
                      • 222
                      • Country: Denmark
                      #25
                      Alistair
                      Cheers, Torben
                      '94 B4 Avant S2
                      • quattrostyle
                        • Oct 2006
                        • 6229
                        http://www.extreme-carstyling.nl/pro...oductID=198157 €299,- for a pair of yellow Koni shocks here. Rears are expensive though
                        • Yaz
                          • May 2007
                          • 445
                          Hi Alistair, hold fire for the moment as I have just set up a trade account with Koni. I'll be getting the prices in a bit, if you're interested?
                          Yaz
                          Alistair
                          1993 Audi Cab 2.3
                          1999 Audi S8 D2 FL
                          • Alistair E
                            • 479
                            #28
                            That would be grea Yaz. Any idea when you will be set up and ready to sell?
                            Alistair
                            • Yaz
                              • May 2007
                              • 445
                              Ok it's setup now, i'll post up some prices in a new thread in the group buy forum soon.
                              Alistair
                              1993 Audi Cab 2.3
                              1999 Audi S8 D2 FL
                              • bilko0795
                                • Feb 2011
                                • 1883
                                Alistair
                                Why have the billi b6s fallen through? i thought yaz was selling them as i will shortly be getting a set for my coupe. Are they still available?
