best place to get urs4 suspension parts. what to change
Ordered loads of bits from http://homepage.internet.lu/customautocraft/
Very very helpful guy, will let you know what things look like when I get the bits.Comment
Did your parts arrive ok? How'd they look? I'm about to order some track rods.Ordered loads of bits from http://homepage.internet.lu/customautocraft/
Very very helpful guy, will let you know what things look like when I get the bits.'93 S4 Avant now back on the road complete with new shiny go faster bits.Comment
Yep came within a few days or ordering. Looks like good stuff, the bottom arms came with new nuts and sleeves washers etc. . Waiting on some Audi only bits before I fit it all.Comment
Just an update. I fitted all new kit to the front. Inc solid subframe mounts. I reset the alignment to toe strait ahead, and 1 degree negative camber. The quality or the parts is great. I found I had a slightly loose ball joint and track rod end. Some small play, but not much. Also the front subframe bushes were very soft. Also there was a tiny clunk/play in the rack, so I tightned the pretensioner slightly and its tight again.
The car feels great at the front now. I can feel the rear wandering slightly, so I must gather up the time to change all the back stuff.
I can definitely recommend getting parts from http://homepage.internet.lu/customau..._S6_S6PLUS.htm
Will let you know how it feels with the rear done too.
Cheers desComment
another update. while doing the rear I came across a rusty, then leaking fuel tank. so I had to get a replacement and therefore I had time to replace the brake cables and I painted all the parts. Will be running again soon. so check your tank out... also the spax dampers in the rear are height adjustable. top work from spax!Comment
