C4Q Rear Control arms
  • Sleeper_Avant
    • 2372
    Andy, chopping all the aligning bits off wont affect it.
    although i would be inclined to take them back off, get rid of the loctite and lather the internals with coppa slip, when you do the locknuts up it aint gonna move!
    • kenax
      • Mar 2010
      • 85
      Are you sure you didnt have the wrong side control arm?
      • PeterS
        • 425
        In my experience on Type 44 and C4s, the aftermarket ones from Meyle and OCAP tend to get surface rust quickly and more annoyingly, squeak.
        Hence I only use Lemfoerder now.
        Peter S
        1990 ErsatzS2 - track toy
        1991 Coupe Quattro
        1991 Coupe Quattro
        1995 S6 Sedan
        1995 S6 Wagon
        • saltinot
          • May 2004
          • 1946
          Where are you sourcing the Lemfoerder parts?
          • Rikki Kitto
            • Feb 2010
            • 6276
            Not sure if it helps but I just got a lemfoerder track arm for my Coupe from Eurocarparts £61
            • K7ERG
              • 1711
              Atp ones on my c4 no issues.
              Audi A6 AEL 5cyl Quattro breaking.
              Audi A5 3.0tdi Quattro Stage 2
              07947385043
              • AndyP
                • 6049
                Well they didn't seem to last long, just 14k and they're fooked
                • popdemonic
                  • Dec 2007
                  • 1304
                  • Country: Thailand
                  #23
                  I just replaced mine 3months ago.they're Febi(Bilstein).so far so good.Lemforder is the OEM for C4 chassis.
                  if you could find one for cheap but AFAIK Lemforder is price 2-3x than Febi's.When i received the Febi's control arms,
                  they were looking neat on the quality though.
                  one of a few I5 from Asia.
                  • AndyP
                    • 6049
                    Just ordered a pair of Febi's
                    • shaun5
                      • 1610
                      Originally posted by AndyP
                      Have you fitted yours yet Phil? Because mine didn't fit without modifcation
                      They have tabs machined on the end of the threaded bar to lock the two ends together
                      As you can see the tabs are machined in the wrong orientation. This is the std one on the left and the Ebay one on the right
                      I ended up cutting the tabs off so I could align them, then put some Loctite on the nuts to lock them in place.
                      Just to say i have fitted my adjuster and as has been discussed they are handed, that is why you had to cut the lugs off. you fitted the incorrect side one
