annoying front suspension rattle.
  • Monkeymagic
    • Mar 2012
    • 3419
    right i am sick of the rattling now. i have been out in the car in the sunshine and the rattling could be heard most of the time...
    do i but compbrake ones, if so which size do i need? or has rusty come up wqith a price yet??
      Have you tried to see if the rattle stops when you gently aplly the brakes?
      My experience with top mounts is that they only rattle at low speeds over bumps.
      • Monkeymagic
        • Mar 2012
        • 3419
        yes lower speeds over small rough sections and it goes under light braking. no noise on new tarmac. getting on my pip. my old man was passenger today and he heard it straight away. it sounds like a slightly loose wheel. its not though. im fairly certain its top mounts probably their demise was accelerated by the kw's
          Yes any uprated suspension will kill OEMs in quick fashion
          Just for a bit of an experiment I have some Leon-R mounts I have modified to fit, they are much taller than OEMs so only really suitable for use with coilovers. Will see how they work
            So if it goes when you scrub the brakes then it could be loose calipers, either the bolts or the sliders loose on the pins?
            • Monkeymagic
              • Mar 2012
              • 3419
              any more info on these. eg part number and mods required? i can do without swapping them every 6 months for a car that does about 3k a year.. im not convinced with the comp brake ones, they just look like they will be harsh and noisy by their very nature.
                No numbers I'm afraid mate, I got them off my mate that fitted some poly ones to his Cupra.
                You just need to mod the diameter and shape slightly, you will see what I mean
                • Monkeymagic
                  • Mar 2012
                  • 3419
                  i see what you mean in principal. i do a few on tt's etc as they generally mishape and start creaking... bloody annoying knowing what is the best answer
                    Yup they are not an ideal design either, but far more substantial than the B3/B4.
                    BTW the Leon-R mounts are much stiffer than TT or Golf IV ones
                    • Monkeymagic
                      • Mar 2012
                      • 3419
                      agreed it must be a better design they tend to fail at 80 to 100k 10 years etc. instead of 80 hours.
                      i dont know wether to try the compbrake one but they ask for diameters of bolts so i guess i need to measure the kw's
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        Yep, you need to give them the thread spec on the top of your shocks, should be M 14 x 1.5 if your using the OE mounts and castle nuts.
                        1990 B3 2.0 80 quattro.
                        1992 C4 2.8 Avant quattro
                        1994 MTM RS2.
                        1998 B5 TDI quattro Sport.
                        2000 B5 TQS.
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          i did use the original castle nut so ill give them a call. did they come with instructions Kit?
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            I got a second set for the back just before Christmas and as far as I recall they don't come with instructions, but to be honest their pretty self explanatory.
                            I'm using them with stock springs now and I really like the set up.
                            1994 MTM RS2.
                            2000 B5 TQS.
                            • Monkeymagic
                              • Mar 2012
                              • 3419
                              I just wondered if you still keep the castle nut. Ill give them a bell i think.
                              • K Simmonds
                                • Dec 2007
                                • 7627
                                No you won't need the castle nut, the Compbrake ones come with a new top nut and a lower guide sleeve, their nice people so give them a ring by all means.
                                1994 MTM RS2.
                                2000 B5 TQS.
