Fiting Bilstein to RS2
  • maRS2
    • Oct 2003
    • 366
    • Home: France Current: Thailand
    I wanted those stiff compression schock absorber because I want to keep th e OE spring to have longer travel of the supension for those bad back B road i have here down south of france and also because those beefy front schock absorber should prevent flex (diameter of the traveling part almost double to the OE Boge).
    But theire is no kit for S2 avant or RS2 from Bilstein
    So I decided to get front one's from coupé S2 and rear one from 2.7T S4 A4
    The front where easy to fit with the QRsport rose joint top mount as it is a direct swap.
    The rear where a litle more tricky!!!
    They are the same length but the part who stop the spring is higher by 20mm wich means that if I fit them like that my car would be 20 mm more high from the back.
    This part is hold by clips in a groove so to get the right hide I made a seconde groove 20 mm lower.
    RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
  • maRS2
    • Oct 2003
    • 366
    Hight difference of the part that carry the spring
    • maRS2
      • Oct 2003
      • 366
      The Chirugical grooving tool!! lol
      By luck exactly the width that the grouve should be
      • maRS2
        • Oct 2003
        • 366
        Grooving
        • maRS2
          • Oct 2003
          • 366
          The new groove
          • maRS2
            • Oct 2003
            • 366
            With the clips on ( ring)
            • maRS2
              • Oct 2003
              • 366
              Now same hight
              • maRS2
                • Oct 2003
                • 366
                On the RS2
                • porkkis
                  • 1994
                  Would it be possible to do a threaded adapter between the spring bottom plate and the shock? This way you could ajust the height, use stiffer ie lowering springs but bring the car back to normal height etc
                  • s2avant
                    • 2426
                    Have you got part numbers for the Bilstein shocks? Wouldn't mind changing out my RS2 dampers for the bilsteins.
                    Ben
                    • alg
                      • Apr 2004
                      • 1160
                      Why not koni ?
                      Who did your rose joint top mount ? QRsport ?
                      Alastair
                      RS2
                      • maRS2
                        • Oct 2003
                        • 366
                        Koni are to soft on compression (going down). if you want good compression behaviour with koni you have to fit them with H&R spring.
                        Bilstein are gas shock absorber stifest in compression available for S2
                        QRSport top mount look on group buy or down here under " top mount where to buy"
                        S2 avant:
                        front part number F4-PE3-3086-H0
                        Back part number F4-BE3-6212-H1
                        Did you send me the subframe alloy bushes didn't get anything yet
                        fabien
                        • alg
                          • Apr 2004
                          • 1160
                          S2 avant:
                          fabien
                          Thanks
                          'Did you send me the subframe alloy bushes didn't get anything yet' Not me
                          Alastair
                          RS2
                          • maRS2
                            • Oct 2003
                            • 366
                            Alg I was talking to S2 AVANT
                            Porkis: I thought about this but you have to unmonted the schock absorber to be able to thread it and also to put on the thread adjustable ring.
                            may be I do it later when have more time like this I can balance front to rear height to tune the car understeering/oversteering
                            • maRS2
                              • Oct 2003
                              • 366
                              S2 Avant:
                              The post man just bring me the alloy subframe bushes
                              Thank's they look great
