Any interest in C4 front uniball control arms?
  • Thuppu
    • 4115
    Just checking if there is any interest in a kit to modify the C4 chassis(UrS4/6, 100, A6 etc.) front control arms inner bushings to solid uniball's? Other solution could be full custom control arms with all steel bearings, even for the swaybar...
    The uniballs would replace the rubber bushings in the pic:
    How about a C4 lower control arm with a replaceable ball joint?
    • Thuppu
      • 4115
      Yes, that was just what I had in mind with full custom arms.
      • A1QSHIP
        • Aug 2004
        • 975
        Like this.
        "Nulla tenaci invia est via"
        • Thuppu
          • 4115
          That would need heavy modifications and weldings on the subframe as it needs new fitting points, and also the swaybar needs to be different. I was thinking of orginal layout but with a control arm made of plate and welded together with uniball cups.
          Something between these:
          • Majorcina
            • Jun 2013
            • 1334
            • Country: Montenegro
            Any update abouth this?
            • Thuppu
              • 4115
              No, not yet.
              • diesel des
                • 3896
                I wonder how harsh these would be in a road car? Track only setup?
                Sent from my GT-N7105 using Tapatalk
                • Mange16v
                  • Oct 2013
                  • 44
                  Originally posted by A1QSHIP
                  I agree with this. I am actually getting a second subframe this weekend to put Thuppus' Subframe bushings in. I'm going to build it with the New control arms I have and use the old one to see if I can come up with an a-arm setup like that.
                  If I fail hopefully ill be able to buy something
                  • Mange16v
                    • Oct 2013
                    • 44
                    Maybe these could be modified?
                    Shop online today for you next set of lowering springs, shocks, coilovers, and more! Our parts are made in the US.
                    • urS6Tom
                      • 773
                      I'd definitely be interested in these Thuppu.
                      • Acki
                        • Mar 2014
                        • 302
                        Any news here?
                        In the moment I following this "path" and I will let you know when I have compared both outer diameter of the stock (inner) bearings:
                        Originally posted by slater
                        for sure, i believe powerflex makes poly bushings for the swaybar ends already. i need to confirm sizes.
                        i believe all of the arms, OE or aftermarket, have the same size bushings. this would be a GREAT solution - i have thought about buying the powerflex units (http://www.powerflex.co.uk/product-d...Bush/1764.html), they need to be pressed into the control arm, and the spacers would have to be machined down as they are too long. they are £55 each, though.
                        peter
                        So far I know that older chassis have smaller outer control arm bearings (for the stabilisator).
                        C4 is bigger than C3/44/43 etc.
                        But I have found a company which offers alle bearings in poly urethan:
                        So outer bearing and front stabilisator bearing are available. Russian guys often install them but I had no chance to ask how durable the stuff is.
                        Inner control arm I favor the uniball version - when it's only to shorten 2 pieces then I will to this.
                        Maybe nice to know, in germany I was able to get ALL bearings from Audi or aftermarket. Front and rear axle.
                        I replaced 2 years ago everything (front incl subframe, rear incl subframe) - control arm rubber is ready for the next replacement, this time I won't do it better.
                        At the rear all bearings were in the same condition like new one (hardness, surface not destroyed) - only the replacement to harder or stiff bearings make sense or when they are really damaged.
                        • ringbearer
                          • Sep 2011
                          • 176
                          I tried the powerflex inner spherical bearings on my C4 and you are right, the hole on the C4 control arm is too big.
                          For the outer sway bar to control arm mount 2Bennett used to make and sell poly bushes but sway bars were breaking off at the ends , not good. They stopped making and selling them as far as I know. Be careful...
                          • Acki
                            • Mar 2014
                            • 302
                            How do you mean breaking off?
                            2Bennett?
                            • ringbearer
                              • Sep 2011
                              • 176
                              Audi service, restoration, performance upgrades, parts and more. 2Bennett is a convenient and cost effective dealer alternative for all Audi years and models. Our 25 years of total focus exclusively on Audis means we understand how to diagnose and repair your Audi like no other. Extensive breadth of diagnostic resources and knowledge, from early examples to newest Audi models. Audi diagnostic equipment as well as parts access directly with Audi USA and Germany helps ensure efficiency and accuracy.
                              The sway bars broke off and no longer located the control arm.
