are b3 and b4 subframes different?
  • Jaswan
    • Apr 2011
    • 765
    i think i seen somewhere that b3 and b4 subframes are different, but iv had a search again and cant find where or what it was i read.
    i think i heard the downpipe on one (b3) goes over and b4 it goes under?
    i had a look at my car before i took out the subframe and there isnt much room between the driveshaft and the subframe for a decent sized downpipe.
    if there is a difference i may look at changing to a b4 front subframe for more clearance.
    and ideas / experience ?
    thanks
  • Kieron20V
    • Mar 2008
    • 1505
    Subframes are the same across the board, the only difference beige the 6speed cars have a slightly higher gearbox mount on one side but you can just use a spacer.
    1994 URS4 Avant RS2+
    • Jaswan
      • Apr 2011
      • 765
      do the downpipes all run over the subframe?
      it looks tight!
        Yep
          There us plenty of room for a 3" downpipe, 3.5" will go if you fettle the lip/flange on the subframe
          Make sure you keep the CV joint heat shield
          • Jaswan
            • Apr 2011
            • 765
            yea i was just thinking to myself that i could mod the subframe before it gets coated.
            cheers all!
