I had a query before about the rear sub frame using different bushings to the front, turns out the larger bushings are slightly taller on the rear sub frame,
Front Sub frame Rear Sub frame
857 199 415 B 857 199 415 B
857 199 419 B 857 199 419 C
In the piccy I have two new rear sub frame bushings sitting along side the alloy mounts, note they are upside down so the bulge part at the bottom sits between the sub frame and the body of the car.
In short I added a few large washers to make up the difference in height, without doing so it will fit fine except the sub frame and diff sit a few MM higher in the car and even closer to the exhaust over the inner driveshaft flange.
Mark.
Mark.
