Audi S2 front shocks.Need info and absorbers.
  • ristokru
    • Oct 2016
    • 270
    Hello,
    Can anyone give me codes for Koni and Bilstein B6 M55 front shocks? I cant find nowhere that info.
    I need new shocks and springs to front and min.40mm lowering.
    And if someone knows where to get with best prize then i would be very thankful!!
    Secondly. If someone have or knows good setup like coilovers then maybe i will go that way.
    Please help me because one of front absorber is run out of oil already
    KW1 seems to be the best Coilover's for a B4 based on cost and performance.
    But obviously a lot dearer than buying two Bilstein front shocks.
    AK Motorsport may sell KW, amongst others. NCTS.
    Others will know more about the Bilstein part of your query.
    See if you can find Bilstein's own web site and go from there ?
    HTH.
    • ristokru
      • Oct 2016
      • 270
      Hello,
      now my one front shock absorber are out of oil and making terrible sound
      I cant find the right code to my car to buy shocks! Can someone help me?
      The right shock is M55 size.
      Also can someone sell me Bilstein or Koni with better prize than store?
      I got one offer and one shock costs 180€
      • Jonas_R
        • 3780
        • Country: Denmark
        For Avant:
        Springs:
        H&R 29909-1 30/30 lowering kit - I can't seem to find anything that is 40/40
        Shocks:
        Bilstein B6 front dampers #34-030868
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • Jonas_R
          • 3780
          • Country: Denmark
          KAW sells this kit for the Avant that is 60/35:
          Click here for KAW kit
          • BorisShakhov
            • Feb 2009
            • 224
            • Country: Russian Federation
            Originally posted by Jonas_R
            For Avant:
            Springs:
            Shocks:
            It`s an awful combintation.
            The first reason is a damper length, you should cut a shaft.
            The second is a rebound force. There should be 4-5 kg/mm linear springs to get an acceptable damping ratio on high velocities and small amplitudes.
            • Jonas_R
              • 3780
              • Country: Denmark
              Then what is a good combination?
              • ristokru
                • Oct 2016
                • 270
                In ebay, Bilstein B6 and B8 costs the same. Maybe B8 is better? Both together 300€
                I want to have daily driver suspension not full track car. So it must be firm but also comfort.
                I want to get lowering springs also because i dont like that my audis nouse is to high
                Can someone in here get better prize to me?
                • BorisShakhov
                  • Feb 2009
                  • 224
                  Koni or some machine work on b6 + custom springs.
                  I`am using machined b6+linear 5kg springs+custom mounts (not a ball bearing design). and it`s very good combo by my taste. You can see it on the pic. #1.
                  It would be great to increase low speed rebound but you can`t do it with this piston because it`ll make more high speed rebound at the same time.
                  I`ve tried a lot of combinations (length, rates, preloads). Just a part of it on the pic. #2
                  There is the force\velocity graph paper somewhere in my garage, I can try to find it if somebody need it.
                  • ristokru
                    • Oct 2016
                    • 270
                    Is there any cheaper version what are good? 300€ two shocks looks a lot.
                    Bilstein B4?
                    • BorisShakhov
                      • Feb 2009
                      • 224
                      Bilstein B4?
                      -40mm on this chassis is not a damper related question at first.
                      You should consider customization or fabrication of parts for (by importance):
                      • steering geometry (bump steer, ackerman)
                      • suspension geometry (roll center correction, camber gain,KPI ,ET and scrub as a moment lever)
                      • Comfort vs handling (damper, spring, bump stop, energy intensity)
                      So I`d choose stock Boge dampers+not sagged oem springs+034 mounts and good custom alignment if we are taking about budget and time.
                      • ristokru
                        • Oct 2016
                        • 270
                        I cant find Boge shocks..
                        • BorisShakhov
                          • Feb 2009
                          • 224
                          I have the same result unfortunately... Listed at AudiTradition for 196 euro.
                          So you can buy b4, it should be tuned to OE specs from a factory and there is no problems to tune them to specs you want at your local damper repair shop.
                          • ristokru
                            • Oct 2016
                            • 270
                            I cant even find Bilstein B4 for S2. I only find B4 M50 but i need M55.
                            • ristokru
                              • Oct 2016
                              • 270
                              So many S2 owners but No help still 😔 Havent nobody changed theyr shock absorders?
