Audi S2 front shocks.Need info and absorbers.
  • rxl
    • 1913
    in your place i would ditch the s2 stuff and go for kw suspension.
    the old one s2 stuff goes like 250 euro and if you put new dampers and springs to lower it it will cost you almoast the same if you just buy kw and sell the other stuff. and kw stuff does not rost and looks like a porn
    • ristokru
      • Oct 2016
      • 270
      Thanks for help. In future i will but KW stuff but right now i only need front dampers. Is there some dampers that dosent cost over 300 euros? Just now i need money to other things.
      I have to put new top mounts also and it would be good if i can change all together.
      • Colesy
        • Feb 2009
        • 2980
        I ran H&R lowering springs with Bilstein B6 shockers and it was a terrible combination as said above. Too harsh a ride and too low for the roads around here. I have also heard that Konis and the H&Rs are a good combo but don't know for sure.
        I put the original springs back on with the Bilstein B6 shockers and have found this to be a great setup. I've run it for around 6 years and wouldn't consider changing it.
          Some B4s here
          https://www.ebay.co.uk/itm/122165365415
          I got my B6s for the avant from this seller. I run them with stock springs and it's perfect.
          • ristokru
            • Oct 2016
            • 270
            Originally posted by newsh
            Some B4s here
            Thank you very much for help! But S2 Outer Diameter is 55mm.
            B4s info:
            Audi 80 Avant (8C, B4) S2 Quattro (169 kW)
            Years of manufacture: 02/93 > 07/95
            Suits Models with a Power Level of 169 kW. This equates to approximately 227 BHP
            Outer diameter [mm] 50
              B4s info:
              Hmm, strange
