hi there,
i currently have the koni / H+r lowered setup - my shocks however need replacing - has anyone here changed the koni shocks for the bilsteins...what was the difference please. Otherwise whats the best setup for the S2..should i stick with new konis.
thanks
imster
hi there,
thanks
imster
im going for rs2 shocks with H&R's, but ive got an avant so i dunno if the RS2 ones will fit yer coupe.
Tim
1995 S2 Avant, ruby red - ** SOLD TO ROSS **
Golf Rallye G60 ** SOLD **
Golf MK2 Oaky with R32 engine
Audi A6 Avant 1.9 TDi 130
Golf MK2 8v Race car
With Bilsteins I think you may have to go back to stock springs, the Billies have a built in air spring assist which would prob make them too hard with H&Rs, dont know for sure but thats the way it is with my ur, stock springs and billies and its really stiff.
If you go for more Konis get the top adjustables, I wish I had Then I could wind them off for driving round here and harder when I need it. I've got the normal Koni Sports on the S2. Taking the car apart to adjust the shocks is a pain.
I didnt think Koni did top adjustables for the S2? Tried to get hold of them for mine and couldnt find them. The RS2 rear shocks are different to the coupe I think, or was that the springs :s
Koni is a bit better in daily drivers comfort wise. Hard to tell performance wise.
Also the 1cm less ground clearance with konis need a bit more attention.
3017 or what ever they quote the B6 sport is std length and the spring will have no "pre load" and that's something our MOT inspectors dislike. Probably yours too.
I mean when rear axle is lifted up the spings may be a bit loose.
B6 with koni springs is probably ok.
Ah i understand where your coming from now! Thanks.
