make sure it's the right tap!
Hub wheel nut thread trouble
if that fails and you have to increase the tap size to M16 you could get an engineering company to turn you a stud with M16 on one side and M14 on the other so you dont have to drill the wheel to take a bigger stud and you can still use the nut that you took off itNautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management
The old Bus
0-60 4.9
1/4mile 13.5Comment
Originally posted by BRYTake the hub out and run a tap through from the back. See what you have then.
This was going to be my suggestion....... that way you will have gone almost all the way thru so will have a definite true line of where the thread should be and might save it for you.Ant
2011 Kawasaki Z1000
Originally posted by Mikes2If you are taking the hub out, buy a new bearing as well
Mike, do you know or is there a how-to on your site for renewing the wheel bearing?Tim
1995 S2 Avant, ruby red - ** SOLD TO ROSS **
Golf Rallye G60 ** SOLD **
Golf MK2 Oaky with R32 engine
Audi A6 Avant 1.9 TDi 130
Golf MK2 8v Race carComment
It's not bad at all. As long as your other 4 nuts are torqued properly, then you are fine. One time, I was at a track event, and i couldn't find 1 of the 20 conical bolts for my racing wheels. the race officials said it was cool...and i ran it without problems.Originally posted by dan_bHow bad is it to run around on 4 wheel nuts, even for just a few miles?
proper thread for the hubs is 14x1.5mm.Joe "NoNonsense"
axis motorsport
joe@axismotorsport.com
"At the end of the game, the king and the pawn go back in the same box."Comment
Originally posted by SteveHWheel bearing removal/refitting needs to be done with the correct tools, press etc. You'll need to have it done for you, it's not really a DIY job..
Getting the hub carrier of the car is OK for the experienced DIY mechanic, but as Steve says - removing the actual hub requires a proper hydraulic press...
Once the hub is removed it can be machined to correct the damaged thread (or renewed worst case).
Of course a new bearing is required to be press fitted into the hub.
It might also be wise to buy a new bottom balljoint as these can be damaged when removing the original hub carrier... My top tip to minimise the risk of that is to loosen both wishbone bush bolts and disconnect the ARB so that when you trying to wriggle/wallop the bottom joint out of the hub carrier that nothing else is working against the direction you want it to go.
Hope that makes sense. Its another one of those 'How To...' jobs that I wish I had time to write up properly with pics etc etc
PaulPaul Nugent
Excellent news!Originally posted by dan_bGarage just phoned - were able to tap the thread no problem, have a nice clean thread now and they have locktited in my new stud, all is well. Thank the Maker!
Very good news indeed. Have also just installed a new rear caliper and tightened up the handbrake cable, so feeling good about the car, hooray! Now it's back to all those other little niggly little jobs, like fixing the rear windscreen wiper, and getting the RS2 hardlines...Ex S2 owner, now running around in an A4 Avant quattro...
Great news!
So there are a couple of lessons in this:
1) Don't get too excited if there is a problem, because the solution may be a lot simpler than you think.
2) Use Loctite to fit studs in hubs!
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second.Comment
