5 speed propshaft to 6 speed gearbox
    I have a spare 6 speed prop if anyone needs measurements?
    • PRY4SNO
      • 767
      Another work around to the spacer is to use the V6 B4 front subframe
      Also, anyone with a spare ABY/6sp propshaft, I'm interested to buy.
      2013 Touareg TDI /// #farmenwagen
      • audiman
        • 4827
        Error404 swap you the prop and part numbers for cost of postage and could you knock me up a 37mm spacer also? I’m also in need of 1 alloy subframe bush! I have a set of 15 here! Ffs
        SteveH yes still got the same number mate. Drop me a text as I don’t have yours any longer.
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
          No problem Tom drop me a PM
