Have a strange issue with the clutch...
When the pedal is pushed down I can change gear without an issue and the pedal returns.
But as soon as the clutch is depressed for a longer period when reversing etc the pedal gradually sticks to the point that the clutch pedal is flat on the floor and the car is in gear.
If I then pull the pedal up manually the clutch can be used again as before.
My thinking is that it is slave cylinder related or perhaps the release bearing.
It hasn't been using any fluid that I've noticed and the master cylinder is dry.
Has anyone had a similar issue before?
